Read write word and Hserin
i confused about my code not working correctly 16f688 with 20 mhz
in first time fill eeprom 254 location with 127 word from rs232 serin data before save it compare
eeprom stored data if no data is same its store if same its not store
and other is if dat word is match led is on also led on by manually by pressing switch one button is for storege [sorry for my bad enlish]
mycode is :
@ DEVICE PIC16F688, HS_OSC, WDT_ON, PWRT_OFF, MCLR_OFF, BOD_OFF,PROTECT_OFF
DEFINE OSC 20
RCSTA = $90 ' Enable serial port & continuous receive
TXSTA = $24 ' Enable transmit, BRGH = 1
SPBRG = 9 ' 115200 Baud @ 18.432MHz, 0.0%
Ctr_A VAR Byte
WR_ERORR VAR Bit
datain VAR Byte[8]
C_Led VAR PORTA.0
LED VAR PORTA.1
IN VAR PORTA.2
STORE_BUT VAR PORTA.3
DAT_A VAR Word
ADDRESS_COUNT VAR Byte
BACK_DATA VAR Word
ADDRESS VAR Byte
MAIN:
HSerIn [Wait($07), Str datain\8]
DAT_A = datain[0]+datain[1]+datain[2]+datain[3]+datain[4]+datain[5]+datain[6]+datain[7]
If IN = 1 Then Toggle LED
For ADDRESS = 1 To 255 Step 2
Read ADDRESS ,BACK_DATA
If BACK_DATA = DAT_A Then
WR_ERORR =1
Else
WR_ERORR =0
EndIf
If WR_ERORR =1 Then GoTo LIGHT
Next
LIGHT:
WR_ERORR =LED
If STORE_BUT = 0 Then GoTo MAIN
PAUSE 50
If STORE_BUT = 1 And WR_ERORR = 0 Then GoTo STORE_IT
For Ctr_A = 0 To 4
Toggle C_Led
PAUSE 150
Next Ctr_A
GoTo MAIN
STORE_IT:
Read 0 ,ADDRESS_COUNT
ADDRESS_COUNT=ADDRESS_COUNT+2
Write ADDRESS_COUNT,DAT_A
For Ctr_A = 0 To 10
Toggle C_Led
PAUSE 90
Next Ctr_A
Write 0,ADDRESS_COUNT
GoTo MAIN
