DT Int-14 seems not working!
I have been using the Rx interrupt with pic 16F88 several times without any problem since today.
The simple code below just go through ISR (Getbytes) only once after reset then no way to see the led_0 showup again, while Led_1 and Led_2 just work as they should.
Anybody sees where the error could possibly be?
INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
;-- Place a copy of these variables in your Main program -------------------
;-- The compiler will tell you which lines to un-comment --
;-- Do Not un-comment these lines --
;wsave VAR BYTE $20 SYSTEM ' location for W if in bank0
wsave VAR BYTE $70 SYSTEM ' alternate save location for W
' Comment them out to fix the problem ----
wsave1 VAR BYTE $A0 SYSTEM ' location for W if in bank1
wsave2 VAR BYTE $120 SYSTEM ' location for W if in bank2
wsave3 VAR BYTE $1A0 SYSTEM ' location for W if in bank3
ANSEL = 0
CMCON = 7
TrisA = 0
TrisB = %00000100
PortA = 0
DEFINE OSC 16
'DEFINE HSER_TXSTA 20h ' Enable transmit, BRGH = 0
DEFINE HSER_SPBRG 51 ' 4800 Baud @ 16MHz, 0,17%
Led_0 var PortB.0
Led_1 var PortB.3
Led_2 var PortB.4
A0 var word
New_L var byte
INT_Handler RX_INT, _Getbytes, PBP, yes
INT_ENABLE RX_INT ; enable RX_INT interrupts
Led_0 = 1
For A0 = 0 to 10
Led_2 = !Led_2
Led_1 = !Led_1
next A0
PortB = 0
goto MainLoop
Getbytes:
Led_0 = !Led_0
@ Return
MainLoop:
Hserin 1,TOut,[New_L]
if New_L > 0 then Led_1 = !Led_1
TOut:
A0=A0+1
if A0 = 1000 then
Led_2 = !Led_2
A0 = 0
goto MainLoop
Thank for the help.
Al.
Re: DT Int-14 seems not working!
Not sure if it is the problem but
is after the ASM block
@ INT_ENABLE RX_INT ; enable RX_INT interrupts
At least that is how the example is done.
http://darreltaylor.com/DT_INTS-14/elapsed.html
Thank you Dave, but it didn't work also with the INT_ ENABLE outside the asm/ endasm block.
Cheers
Al.
You do not return from your int routine. Use @ INT_RETURN
Thanks Ioannis, you spotted the problem! Now it works.
Cheers
Al.
Glad you got it working. You are welcome.
