Communication between two PicChip
hello,
I am trying to transfer data from one Pic16F88 to another F88 chip. is there a method better then the other one. I only have 4 ports left (one is use for adcin, one for ground between the two chips and two for serin and serout). The only alternative I know but would cost a bit more is to use an external EEPROM..
I have A master program and a Slave program, here is the code, I think it is self explanatory:
PortB.7 is hooked up to the PortB.0 (interrupt) of the other chip
Master:
SetRTCTime = 125
ViewTime = 0
I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]
Pause 30
serout portb.7, n2400, [$55, $55, $55, $55, $aa, SetRTCTime, ViewTime, StartTimeHour ]
serout portb.7, n2400, [StopTimeHour, StartTimeMin, StopTimeMin, RTCYear, RTCMonth, RTCDay, RTCHour, RTCMin ]
Pause 100
lcdout $FE,1, "upload Time Int"
lcdout $FE,$C0, "Completed"
pause 1500
Slave:
'/////// MyInterrupt ////////
DISABLE
MyInterrupt:
waitfor55:
serin portb.0 , n2400 , temp : if temp <> $55 then goto waitfor55
waitforaa:
serin portb.0 , n2400 , temp : if temp <> $aa then goto waitforaa
serin portb.0, n2400, SetRTCTime : serin portb.2, n2400, ViewRTCTime
serin portb.0, n2400, StartTimeHour : serin portb.2, n2400, StopTimeHour
serin portb.0, n2400, StartTimeMin : serin portb.2, n2400,StopTimeMin
serin portb.0, n2400, Year : serin portb.2, n2400, Month
serin portb.0, n2400, Day : serin portb.2, n2400, Hour
serin portb.0, n2400, Minute
If (SetRTCtime = 125) then
I2CWRITE SDApin,SCLpin,$D0,$00,[$00,Minute,Hour,$00,Day,Month,Year,$00] ' Write to DS1307 to initialize a new time
pause 30
Endif
If (ViewRTCTime = 55) then
Pause 30
serout portb.7, n2400, [$55, $55, $55, $55, $aa, SetRTCTime, ViewTime ] 'if 222 then
pause 200
serout portb.7, n2400, [$55,$55,$55,$55,$55,$aa,RTCYear, RTCMonth, RTCDay, RTCHour, RTCMin, RTCSec]
serout portb.7, n2400, [StartTimeHour, StopTimeHour, StartTimeMin, StopTimeMin]
Endif
INTCON.1 = 0 ' Enable external Interrupt
RESUME
ENABLE ' Enable Interrupt
The problem now is that the information is not transfering. And this is not a method to get a ACK and verify information transfered.
Re: Communication between two PicChip
I think you are crazy to not use the HARDWARE serial port. That would make things almost trivial. Is there some reason why you aren't using it?
Its takes three pins from my chip
: Serial Data Out (SDO) RB2/SDO/RX/DT
• Serial Data In (SDI) RB1/SDI/SDA
• Serial Clock (SCK) RB4/SCK/SCL
I am already using SDA and SCL to program and read my RTC. Unless I can use the same pin for both..
Why don't you use I2C also for the communication from pic to pic? Pic 16F88 can operate as slave, so you will give it an address and you will transfer all the data with I2CWRITE and I2CREAD, simpler than that! You can find a working code for I2C slave on the forum, I posted it sometime ago and I don't remember where is burried.
Cheers
Al.
PS. I found it! http://www.picbasic.co.uk/forum/show...ight=I2C+salve
When I mentioned hardware serial port, I was referring to TxD and RxD. Then you could use HSEROUT and HSERIN. Connect those two lines together on your PIC, and you can communicate at 9600 baud at least, on the internal oscillators.
I just want to do a very simple communication at first, then I will work on better one. I am using the same code as i used a few ago for a project on mine. It was working fine at the time. I was using a different compiler and different software.
I am trying to re-use that code. Now I have taken THE code I used and just removed the extra stuff in the programming that is not needed ( calculation from a wireless thermometer) here is my sending code:
INCLUDE "modedefs.bas"
OSCCON = %01110000 '8 Mhz
Define OSC 8
CMCON = 7 : ANSEL = 0 : ADCON1 = 7
'// LCD configuration //
DEFINE LCD_DREG PORTA ' Set LCD Data port
DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSBIT 0 ' Set LCD Register Select bit
DEFINE LCD_EBIT 6 ' Set LCD Enable bit
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
DEFINE CHAR_PACING 2000
TRISB = %00000000
count_remain var byte
temperature1 var byte
temperature2 var byte
Mainloop:
temperature1 =11: temperature2 =22
count_remain =44
lcdout $FE,1, "TempC: ", dec (temperature1) , ".", dec2 temperature2," ",$DF,"C"
lcdout $FE,$C0, bin count_remain , ".","F"
pause 400
serout portb.2, n2400,[$55,$55,$55,$55,$aa,temperature1,temperature2,coun t_remain]
lcdout $FE,1 : LCDOUT "second ", dec (temperature2 / 100) , ".", dec2 temperature1," ",$DF,"r"
lcdout $FE,$C0, dec count_remain , ".","23"
pause 400
goto mainloop
and here is the receiving code:
Define OSC 8
ADCON1 = %00100010
encoded11 var word : encoded22 var word : encoded33 var word : encoded44 var word : encoded4 var byte
count_remain var byte :temp var byte
TRISA = %00000001 ' Set PORTA to all output
TRISB = %00001111
Mainloop:
'23
lcdout $FE,1 , "hello ", dec 105," ","C"
lcdout $FE,$C0, "before"
pause 300
waitfor55:
serin portb.2 , n2400 , temp : if temp <> $55 then goto waitfor55
waitforaa:
serin portb.2 , n2400 , temp : if temp <> $aa then goto waitforaa
serin portb.2, n2400, encoded11.HighBYTE : serin portb.2, n2400, encoded11.LowBYTE
serin portb.2, n2400, encoded22.HighBYTE
lcdout $FE,1, "encoded11.HighBYTE", dec encoded11.HighBYTE , ".", dec2 encoded11.LowBYTE
lcdout $FE,$C0, "TempF: ", "-", dec encoded22.HighBYTE , "After"
Pause 300
goto Mainloop
the sending code seems to work. but the receiving code seems to be stuck on the first LCDOUT, I guess it does not see the 55 or aa...
k
That is why you need to use the hardware serial port! If you use SERINx you have to sit and wait for the first transition of the start bit of the first char to come in. If you use HSERIN instead, you could simply test for PIR1.5 (at least that is what it is in the 18Fs). It gets set AFTER the whole byte is received, so in just a few instructions, you can tell if the first byte came in. If that bit isn't set, move on. If it is set, then you know there is a char in the receive buffer, so then you can issue the command HSERIN [dummy]. If Dummy = $55 then you can continue to grab chars. Virtually no overhead, and as long as you give it a
little thought, you don't even need interrupts. It will NEVER lose the first character.
Although I always advocate using interrupts, if you didn't want to mess with them, you could:
Figure out the loop time of your slave device. Then you could do the following:
GotChars = 0
If PIR1.5 then
Hserin [FirstByte] ;------------ You don't need a timeout here because you already know you have a char
if FirstByte = $55 then
HSERIN 50,NotValid, [STR receivebuffer \numbytes]
GotChars = 1
NotValid:
....rest of program here....
And your master -
HSEROUT [$55]
pause (this should equal the length of the slave's program loop + a few mSec)
HSEROUT [whatever you want to send]
i know what you mean. but why did it work before and now it does not.... i can see from my scope the the same signal is going in the pic.. why the heck doesn't it read it.
K
Maybe you should try smaller-value pull-up resistors. Although most I2C devices can't sink much current, a PIC can sink 25mA easily. You could use 560 ohm pull-up resistors on each end if you had an extremely noisy environment or long wires.
Also, if your two devices aren't on the same PCB, could there be a difference in GND potential between the two devices?
and i do have a I have the two breadboards sitting side by side, so maybe 9inch of wire between the two. I added 560ohmpull up resistors but nothing changed from before. and I do have a ground wire between them ..
WHAT is the best technique to communicatebetween two Pic Chip ??
I2C ? HSEROUT ? .....
There are so many answers to that question. "Best" is a big word.
While there are lots of options, just quit fighting and use HSEROUT/HSERIN. Easy to use, and has full PBP and DT-INT support. It is a waste of my time to try to convince you of anything. If you choose to use that method I propose, I will give you some pointers, if you don't, you will have to look for help from others.
I was heading in that direction using HSEROUT, starting reading the pic datasheet communication section and that led me to ask that question. I'll be working on HSEROUT tonight. I think it is a better practice then using serout in a free style way.
STILL NOT TRANSMITTING. as least I am getting any compilation errors..: here is my transmitter code:
(I just see these before word on my LCD)
OSCCON = 110000 '8 Mhz
Define OSC 8
' Set transmit register to transmitter enabled
DEFINE HSER_TXSTA 20h
' Set baud rate
DEFINE HSER_BAUD 2400
' Set SPBRG directly (normally set by HSER_BAUD)
DEFINE HSER_SPBRG 25
cou var byte
temp1 var byte
temp2 var byte
Mainloop:
temp1 =18: temp2 =22
cou =44
lcdout $FE,1, "TempC: ", dec (temp1) , ".", dec2 temp2," ",$DF,"C"
lcdout $FE,$C0, bin cou , ".","F"
pause 400
Hserout [DEC temp1]
PAUSE 50
lcdout $FE,1 : LCDOUT "second ", dec (temp2 / 100) , ".", dec2 temp1," ",$DF,"r"
lcdout $FE,$C0, dec cou , ".","23"
pause 400
goto mainloop
and my receiver code
Define OSC 8
' Set receive register to receiver enabled
DEFINE HSER_RCSTA 90h
' Set baud rate
encoded22 var word
Mainloop:
pause 300
Hserin [DEC encoded22]
PAUSE 100
lcdout $FE,1, "after"
lcdout $FE,$C0, "AFTER: ", "-", dec encoded22 , "After"
Pause 300
goto Mainloop
How are the two chips connected?
chip#1 ground to chip#2 ground
chip#1 TX to chip #2 RX
YES THE CHIPs has a common ground. RB5 is going to the receiving pic on RB2 (PIC16F88)
ken
Try these settings on both the Tx and RX chip
DEFINE HSER_SPBRG 51 ' 2400 Baud @ 8MHz, 0.17%
just copied and paste your code and still did not work. Same as before.....
ken
Do you have your TX pin set for output (TRIS = 0)?
i ADDed this after I sent the code yesterday.:
TRISB = %00000000
AND
the other pic:
TRISB =%11111111
could it be in the include file?
K
If you are talking about "modedefs.inc" no. You do not need that file for what you are doing so it is not doing any harm. It is for SERIN/SEROUT and a couple other commands.
Have you tried sending/receiving to a PC?
nO DID NOT SEND TO pc. Actually never done that in my life....
If you are using the hardware serial port (as I suggest), then the polarity will be wrong for a direct connection to a PC, so that won't work.
If you issue HSEROUT [...] and the port doesn't even toggle, then you have some other problem.
I can some steady activity on the HSEROUT port. Seems to me the receiving end is a problem. I used another picF88 chip in case it would be a hardwire pin problem, but still the LCD is not showing the input. I removed the First LCDOUT and juste the one after the HSERIN and the L:CD is showing blank...
Are you using HSERIN for the receive side?
Just do this -
LCDOUT $FE,$1
Topp:
HSERIN [X]
LCDOUT X
Goto Topp
this is what I have now. the tiny rail of the breadboard seems to be defective, although I tested it with my multimeter and it seems to be conducting, but then if I put the wire from the transmitting pic directly to the receiving chip leg then I could see something on the LCD. that fixed. I am sending 5 or 22 or 85 from the TX pic and I am always receiving 49 on the RX chip....
Mainloop:
Pause 50
Hserin [encoded22]
PAUSE 100
lcdout $FE,1, "input ", bin encoded22
pause 200
goto Mainloop
I removed the defines commands for HSERIN, ans used the serout command. It WORKS !!!. But i would like to make the HSEROUT AND HSERIN command works. I still get the number 48 or 49 showing up. sometimes after a minute or so the LCD shows some erratic behaviour, showing a lot oo???oo?? on both of the line.....
any ideas?
k
i CHANGES BREADBOARD, USED BRAND NEW CHIPS, STILL i AM GETTING 49 IN THE RECEIVING PIC................ANY IDEAS ???? OUPS CAPS LOCK...
Ken
