Send power betwwen to moving parts?
Hey Guys
Long time since I wrote for the last time here, I don't have much time free lately I'm afraid.
Well, short question, I need to send 5 volts between two moving parts, like the famous "propeller clock" or like in a slot car.
What I'm trying to find is some nice rigid contacts to attach to a PCB, so they can slide over another PCB to transfer the 5 volts.
Like this:
http://www.youtube.com/watch?v=qlw6pFg-pvk
Hope it's clear what I'm trying to do. Any ideas or suggestions?
Thanks!
Daniel.
Re: Send power betwwen to moving parts?
danielhr77
Hey Guys
Like this: . . .
Thanks!
Daniel.
Hi Daniel,
Since your application is low power, I E Not several tens of amps, You might consider carbon brushes, I think Home Depot may sell them or LOWES as general purpose replacements for motors. A split ring commutator can be fashioned from copper tubing and epoxy and bruch holders from brass tubing and pc board.
Archangel
Hi Daniel,
Whilst you can certainly use carbon brushes, they are typically used where high currents in the tens to hundreds of amps are required. A good example is the starter motor in a motor vehicle.
rmteo
Huh, I've never seen a straight carbon brush in a starter, seen a copper blend there, alternators however do use carbon brushes. The brushes I am refering to are very small round or square light motor brushes designed to handle less than 10 amps and are soft enough to run on a copper surface without destroying it . They have the desirable attribute of having a fine braided copper wire embedded so as to give you a way to energize them without adding another friction connection. Many also have an attached coil spring. Example from OSH http://www.osh.com/eng/product/dreme...rushes/6067128
or better, Grainger's
http://www.grainger.com/Grainger/wwg...FUvCtgodhk5KpA
Although the cheapest method might be to cannabalize a toy's motor.
Starter Motor Brushes
http://www.amazon.com/Ricks-Motorspo.../dp/B00230JUMY
