Disabling MCLR pin
I am trying to disable the MCLR pin because I am using it to do a LCDOUT on that Pin.
I am using a PIC16F88.
I read this thread but it is not helping me out.
I still get compiling error.. illegal upcode
'LCD testing program and Clock viewing
INCLUDE "modedefs.bas"
OSCCON = %01110000 '8 Mhz
Define OSC 8
CMCON = 7 : ANSEL = 0 : ADCON1 = 7
@ DEVICE pic16F88, MCLR_OFF
'// LCD configuration //
DEFINE LCD_DREG PORTA ' Set LCD Data port
DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSBIT 7 ' Set LCD Register Select bit
DEFINE LCD_EBIT 6 ' Set LCD Enable bit
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
DEFINE CHAR_PACING 2000
Re: Disabling MCLR pin
DATA sheets are your friend.
Please read the chips DATA sheet and make it happy :)
MCLR is an input only.
I guess I have to find a way to use the LCd another way then, I need the SDA and SCL pins and the Vref,s pins....
also how come do I get the illegal upcode ???
K
