OWIN - OWOUT problem
I have a problem trying to use other port pins along with OWIN and OWOUT
When I try to make a port pin high, (on the same port as OWIN and OWOUT), the pin only remains on for about 20 US, which is probably about the time to complete the loop (using the attached program).
I am not very familar with OWIN and OWOUT . . . Does the command change all the pins back and forth from input to output, etc on that particular port? The SERIN2 command works fine, using a pin on the same port. When I change to another port
(PORTB in this case), everything is fine, the output remains on. I am using a simple test in the attached program, eventually I will be turning the output on and off depending on temperature.
I tried using the LAT command on the port pin, thinking it might be a read - modify - write problem, and get a "bad data type" error trying to compile.
The program is a modified version of one of Bruce's for the DS18B20. The program works just fine. I'm using a 16f876A running at 4 MHz.
I have commented the problem areas surrounded by a !!!!!!!!!!!!!!!! boundary
'* Name : DSB1820 *
'* Author : K. STUEMPGES ( VIA Bruce Reynolds) *
'* Date : 27 OCT 2011 *
'* Version : 1.0 *
'* Notes : MODIFIED FROM BRUCE REYNOLDS PROGRAM *
'* : TO USE WITH A PIC 16F676A *
'* : A RELAY WILL BE USED TO CYCLE THE INVERTER *
'* : USED ON THE FREEZER (ON - OFF WITH HYSTERESIS) *
'* : THE FREEZER TEMP WILL BE FROM 0 TO 15 DEGREES F *
DEFINE OSC 4 ' INTERNAL OSCILLATOR
TRISC = 000000
TRISB = 010000
Comm_Pin VAR PORTC.0 ' One-wire Data-Pin "DQ"
RELAY VAR PORTC.6 ' OUTPUT TO DRIVE THE RELAY
' THIS IS THE OUTPUT THAT WILL NOT STAY HIGH USING ANY OTHER PORT C PIN
' IT WORKS FINE USING PORT B
DISP VAR PORTC.3 ' SERIAL LCD OUTPUT
ALARM VAR PORTB.3 ' OUTPUT TO SOUND ALARM
SWITCH VAR PORTB.4 ' TOGGLE SWITCH INPUT
Busy VAR BIT ' Busy Status-Bit
R_Temp VAR WORD ' RAW Temperature readings
TempC VAR WORD ' Temp in deg C
TempF VAR WORD ' Temp in deg F
Float VAR WORD ' Holds remainder for + temp C display
Cold_Bit VAR R_Temp.Bit11' Sign-Bit for +/- Temp. 1 = Below 0 deg C
Real_Cold CON 1 ' Define Real_Cold = 1
Deg CON 223 ' Data to display Deg ° symbol
Sign VAR BYTE ' +/- sign for temp display
Dummy VAR BYTE ' Dummy for Div32
CLR CON 1 ' CLEAR DISPLAY
LINE1 CON 128 ' FIRST LCD LINE
LINE2 CON 192 ' SECOND LCD LINE
LINE3 CON 148 ' THIRD LCD LINE
LINE4 CON 212 ' FOURTH LCD LINE
INS CON 254 ' LCD COMMAND MODE PARAMTER
BAUD CON 84 ' LCD BAUD COMMAND
SEROUT2 DISP,BAUD,[INS,CLR] ' clears the display
Start_Convert:
OWOUT Comm_Pin, 1, [$CC, $44]' Skip ROM search & do temp conversion
Wait_Up:
OWIN Comm_Pin, 4, [Busy] ' Read busy-bit
IF Busy = 0 THEN Wait_Up ' Still busy..?, Wait_Up..!
OWOUT Comm_Pin, 1, [$CC, $BE]' Skip ROM search & read scratchpad memory
OWIN Comm_Pin, 2, [R_Temp.Lowbyte, R_Temp.Highbyte]' Read two bytes / end comms
GOSUB Convert_Temp
GOTO Start_Convert
Convert_Temp: ' +32.0 to +257 F
IF Cold_Bit = Real_Cold THEN Yikes ' If Cold_Bit = 1, it's below "0" deg C
Sign = "+"
Dummy = 625 * R_Temp ' Multiply to load internal registers with 32-bit value
TempC = DIV32 10 ' Use Div32 value to calculate precise deg C
Dummy = 1125 * R_Temp
TempF = DIV32 100
IF TempF >6795 THEN ' Over 99.5 deg F..?
TempF = TempF + 3200
SEROUT2 DISP,BAUD, [INS,LINE1, " Temp = ",Sign,DEC TempF DIG 4,_
DEC TempF DIG 3,DEC TempF DIG 2,Deg," F "]
SEROUT2 DISP,BAUD, [INS,LINE1, " Temp = ",Sign,DEC TempF DIG 3,_
TempC = (R_Temp & $0FF0) >> 4 ' Mask middle 8-bits, shift into lower byte
'Float = ((R_Temp.Lowbyte & $0F) * 625) ' Lower 4-bits of result * 625
SEROUT2 DISP,BAUD, [INS,LINE2, " Temp = ",Sign,DEC TempC,Deg," C "]
RELAY = 1
' THIS OUTPUT ONLY STAYS HIGH FOR APROX 20 US.
' IT WILL REMAIN ON USING ANY PIN ON PORTB
Yikes: ' Display full range -C to -F conversion
Sign = "-" ' Display - symbol for negative temp
Dummy = 625 * ~R_Temp+1' Multiply to load internal registers with 32-bit value
TempF = ~R_Temp / 16 ' Begin conversion from -C to deg +/-F
IF TempF >=18 THEN ' Check for -degrees F "-18 C = -0.4 F"
TempF = ((((TempF + 50) * 9) /5) -122) ' -C to -F below -17 deg C
SEROUT2 DISP,BAUD, [INS,LINE1, " Temp = ",Sign, DEC TempF,Deg," F "]
SEROUT2 DISP,BAUD, [INS,LINE2, " Temp = ",Sign,DEC TempC dig 4,_
dec TempC dig 3,Deg," C "]
ELSE ' Else result = +deg F
TempF = ((((-TempF + 50) * 9) /5) -58)' -C to +F below 32.0 deg F to -17 deg C
SEROUT2 DISP,BAUD, [INS,LINE1, " Temp = ","+",DEC TempF,Deg," F "]
dec TempC Dig 3,Deg," C "]
Re: OWIN - OWOUT problem
"Upon further review" I found that the owin / owout is not causing this weirdness. It seems to be the result of using serout2. I switched ports around, etc, and found that when I have the serial out on the same port as my test LED, that is when the on/off problem occurs. Moving the statement around in the program has no effect.
I guess I will simply just dedicate one port to the serout2 command, and do everything else on a different port. Thankfully I have spare pins available for what I need to do
Ken
