Re: 16F1827 interrupt hosed
Try adding BSR=0 as the first asm instruction in your ISR. If this works, I will be happy to explain why. But if not the reason will confuse the issue.
Very strange...I did what you suggested but it only prolonged the end result. I am seeing two things when the interrupt crashes....either it hoses the main loop and the interrupt oscillates at a high frequency of 235 Khz or it completely stops and main keeps going with its toggle. This is what I added to the ISR.
asm
; Save W, STATUS and PCLATH registers, if not done previously
myint
; retfie auto-restores w, status, bsr, fsr and pclath
bcf BSR,0
bcf T1CON,TMR1ON ; stop timer 1
bcf PIR1,TMR1IF ; clear over flow flag
movlw 0xEF ; load timer for 16,535 * 2 prescaler interrupt on 16 bit timer
movwf TMR1H ; load high byte
movlw 0xEF
movwf TMR1L ; load low byte
bsf T1CON,TMR1ON ; re-enable timer 1
movlw 0x02
xorwf PORTB,f ; toggle RB1
retfie ; Return from interrupt
endasm
Try bsr=0. There maybe more bank select bit then just 1.Like this:
Myint
Bsr=0
asm
Rest of isr
OR
myint
asm
clrf bsr
rest of isr
here is what I think is happening:
When the INT is called, the state of the BSR is unknown. If the main program is doing something that requires bsr to be other then 0, when you enter the ISR you can't manipulate the things in the ISR because the wrong bank is selected.
When you added the BCF BSR,0 - This almost fixed it but not quite. When it stays in the ISR that is because you can't clear the flag (acting on wrong reg, NOT PIR) so the INT just fires forever. My guess is when you think the main is running without INT, that may be not true, it may be that you just aren't toggling the output so you think the ISR has not fired.
The easiest way I know of to troubleshoot this is using MPLAB SIM inside of MPLAB. put a breakpoint at the first line of the ISR, then when it fires you can single step through while watching reg's like port b and even better BSR!
Thanks for your help! I will try your suggestion. I did notice one thing before leaving the office last night, when I remove the ADC from main everything works well. When I rerun the test using ADC enabled it screws things up. Do I need to also do something with T1CON like select a bank of memory that it can write to that is common across banks? some how I think writing to values to the timer is somehow not being read out of the correct bank at some point after the interrupt is enabled upon exit....just my guess.
Nick
BSR will be restored when you exit the ISR. That chip auto saves and restores W,PC,Status, BSR, I think. So no need to worry about it from the Main point of view. I have not checked the banks you are using in the ISR, but I am thinking since it works sometimes they may be all in BANK 0. Could be the ADC is whats creating the NON bank 0 setting in the BSR.
Bert,
Thanks for the help. I used your suggestion in conjunction with BANKSEL T1CON at the start of the ISR after the ASM tag. It all works now!!!
Nick
do you understand why? sounds like you do. BTW DT_INT takes care of BSR for you I think. I am being pushed towards using them and prolly will end up there. Just an FYI.
I am seeing something strange.....It seems I can not read my ADC's or run anything in main when my interrupt is enabled. What my code is supposed to do is output a 1.5ms pulse every 16ms for "home" position on 4 servo's in the interrupt. At any time an ADC value on 5 ADC's is above a threshold I want to stop the interrupt and run the scaled up ADC values to run my servo's in real time. What am I missing?
__config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
__config _CONFIG2, _PLLEN_OFF & _LVP_OFF & _LVP_OFF & _STVREN_OFF
DEFINE OSC 8
;Define ADCIN parameters
DEFINE ADC_BITS 8 ' Set number of bits in result
DEFINE ADC_CLOCK 4 ' Set clock source, look on data sheet for chart
DEFINE ADC_SAMPLEUS 500 ' Set sampling time in uS
DEFINE INTHAND myint ' Setup interrupt handler
; System hardware configuration
OSCCON = %01110000 ' bit.7 =32MHz internal
ANSELA = %00000001 ' all digital. A/D disabled
ANSELB = %00000000
TRISB = %00000000 ' set port directions 0 = output, 1 = input
TRISA = %00000001
ADCON0 = %00000111 ' Set PORTA digital 1, analog 0
ADCON1 = %01000000
; Program variables
ADCVAL var byte bank0
ADCVAL2 var byte bank0
ADCVAL3 var byte bank0
ADCVAL4 var byte bank0
ADCVAL5 var byte bank0
; Program constants
centM con 1500 ;motor stop
forM con 2000 ;motor forward
revM con 1000 ;motor reverse
; Power on initialization to known port states
PowerOn_init:
PortA = 0 ' force low to avoid glitches
POrtB = 0
PIR1 = 0 ' clear TMR1 int flag
PIE1 = %00000001 ' TMR1 int enabled
INTCON = %11000000 ' global & peripheral ints enabled
T1CON = %00010001 ' TMR1 1:2 prescale, timer1 on
goto mainloop
asm
myint
BANKSEL T1CON
clrf BSR
movlw 0xBF ; load timer for 16,535 * 2 prescaler interrupt on 16 bit timer
movlw 0xFF
call _home
; movlw 0x02
; xorwf PORTB,f ; toggle RB1
endasm
home:
if adcval < 4 and adcval2 < 4 and adcval3 <4 and adcval4 < 4 and adcval5 < 4 then
PORTB = %00001111
pauseus 1500
PORTB = %00000000
mainloop:
call readADC
call spin
' call forward
' call back
' call left
' call right
pause 15
goto mainloop
readADC:
adcin 0, adcval
ADCIN 1, adcval2
adcin 2, adcval3
adcin 3, adcval4
adcin 4, adcval5
spin:
if adcval > 4 then
LATB = %00001111
pauseus 6*(adcval) + 900
LATB = %00000000
forward:
if adcval2 > 4 then
LATB = %00001100
LATB = %00000000
LATB = %00000011
LATB = %00000000
back:
if adcval3 > 4 then
LATB = %00000011
LATB = %00000000
LATB = %00001100
LATB = %00000000
left:
if adcval4 > 4 then
LATB = %00000101
LATB = %00000000
LATB = %00001100
LATB = %00001010
right:
if adcval5 > 4 then
LATB = %00001010
LATB = %00000000
LATB = %00000101
LATB = %00001010
Try changing
call readADC
call spin
to
GOSUB readADC
GOSUB spin
From the manual:
CALL
CALL Label
Execute the assembly language subroutine named Label.
GOSUB is normally used to execute a PICBASIC PRO™ subroutine. The main difference between GOSUB and CALL is that with CALL, Label=s existence is not checked until assembly time. Using CALL, a Label in an assembly language section can be accessed that is otherwise inaccessible to PBP.
See the section on assembly language programming for more information on CALL.
CALL pass ' Execute
assembly language subroutine named _pass
Hello Dave,
I changed the calls to subs and still nothing runs in main while the interrupt is enabled. I can't even get a simple portb.0 set / reset to give me anything on the I/O.
Nick
CALL or GOSUB doesn't make any difference.
But you cannot run Basic Language statements in an Assembly Language interrupt.
Re-use of PBP's system variables will corrupt the main programs flow.
If you want to use Basic statements in ASM interrupts, you need to either use ON INTERRUPT or DT_INTS.
Darrel,
How would I structure my code using your interrupt include file? I want to accomplish the following:
1). update 4 servo's with a refresh rate of 16ms. Pulse width on the servos range between 1 ~ 2 ms based on reading 5 ADC channels.
Best Regards,
Nick
I found this in the new PBP3 Reference Manual on page 264
"Whenever a block of inline Assembly Language is entered, PBP sets the bank-select register to BANK0".
So, why does Nick have to manually select BANK0 using BANKSEL T1CON? It's true that all of the registers in his ISR are in BANK0. And yes, all his A to D registers are in BANK1, but why isn't PBP doing the switch to BANK0?
Good catch! Looks like I updated pbp but not my brain. Yet another good reason to upgrade :)
Darrel are you referring to the pauseus? If so are the rest non system variable things?
Macgman2000
... How would I structure my code using your interrupt include file? ...
I guess the structure would look a lot like the examples found here ... http://www.darreltaylor.com/DT_INTS-14/hello.html
Look at the Hello World, Blinky Light, Elapsed Timer and then how they are combined 1-3.
cncmachineguy
That is a compound if statement, meaning there is more than one condition to be tested.
That requires it to store intermediate results in T? temp variables, which are part of PBP's system vaiables.
The compares themselves will call a library function that uses R? system vars.
PAUSEUS will overwrite the R0 system variable.
PAUSE would use R0 and R1.
It's very difficult to know which statements will interfere with which system variables.
So it's best not to tempt fate.
