Serin parameters ??
Hi all,
i want to read serial data using serin but the trame i am receiving is not always with the same size and it has not always the same bytes at the end (to wait for and stop reading).
i want to use it as when using hserin ( hserin timeout,label,[str buffer\80] ) if possible, but i noticed that i can't use "str variable\x", any help :confused: ??
Thank you :)
Re: Serin parameters ??
perhaps SERIN2 or DEBUGIN?
i think serin2 will work, i didn't pay attention for that before :(
thank you Steve :)
i am trying with serin2, the timeout is working properly,
but i faced another problem which is the [str varname\n]
serin2 IN_PIN,84,[str buffer\2] ' baud 9600
if buffer[0] = "A" and buffer[1] = "B" then
LED1 = 1
LED2 = 0
LED1 = 0
LED2 = 1
The above code makes LED2 ON when sending "AB" to the microcontroller (which is wrong) while the below code makes LED1 ON (which is correct)
serin2 IN_PIN,84,[buffer[0],buffer[1]]
LED1 = 1
LED2 = 0
LED1 = 0
LED2 = 1
where is the problem in my code ???
i have a buffer of around 50 bytes, so it is preferable to use the [str buffer\50]
Note that i tested the debugin instead of serin2, but same problem !!!
mmm... weird, will test it here. Which PBP version do you have?
