Has anyone designed a USB-ICSP programmer circuit?
I have completed a project that I thought could be adequately maintained by manually programming software updates as necessary by running around with a laptop and a conventional USB programmer, or PICSTIC. The handwriting is on the wall now, and I can see that the software updates are never going to end, and I'm going to be making field trips forever :eek:
I would like to add a piggyback USB programmer circuit to my circuit board that had a USB input and connected to the usual ICSP header. (The USB input would come from a linux based computer that is also included in the project, and network connected.) The linux pc part of the project was not mine, so the software would need to be fairly 'generic'. My question: Has anyone already done this and willing to share their circuit/software?
Best regards to the group.
Re: Has anyone designed a USB-ICSP programmer circuit?
You might take a look at the Amicus setup. I have not tried it in Linux yet.
http://www.picbasic.co.uk/forum/cont...r=346-amicus18
Thanks, Dave. I'll give it some study over the w/e!!
Thank you MisterE. Guess the hard work is mostly done!!
MeLabs do a USB to ICSP programmer. I think it's called U2.
It has a EPIC style ICSP connector so you will proba\bly need to design your own interface cable to suit your particular target ICSP connection type, of which there doesn't appear to be a standard.
