		PIC hanging on Serin
		Hi, I am new to the forums(and to Pic's) and have been trying to learn about serial communications between different chips.  I have a PIC16f688 and am trying to communicate with a 3.3V device and a Hyperterminal over RS232.  I have been successful communicating with the Hyperterminal so far, but receiving communications form the 3.3V chip to the PIC have not been so successful.  I have used an inverter chip to adjust voltage levels coming from the 3.3V chip to the PIC to 0-5V logic.  I also have a monitor that came with the 3.3V device that allows me to see what the chip is responding in HEX format.  I have even used a scope to see the waveforms being output from the 3.3V device.  I am stumped as I see the reply from the 3.3V chip in the provided monitor and on my scope, but the PIC is hanging on the Serin call.  Here is the code that I am using:
 Include "modedefs.bas" 'includes Serial functionality
 Define OSC 4 'use the 4 MHz internal oscilitor
 HTO var PORTC.4	'make RC4 output hyperterm
 HTI var PORTC.5 'make RC5 input	hyperterm
 XBI var PORTC.1 'make RC1 input XBEE
 XBO var PORTC.2 'Make RC2 output XBEE
 TRISC = %101010 'Sets the directions of the bits on portc
 ANSEL = $11 'port c digital io
 b0 var byte 'the variable to store the input into
 b1 var byte
 b2 var byte
 b3 var byte
 b4 var byte
 b5 var byte
 b6 var byte
 b7 var byte
 'byteArr var BYTE[8]
 i var byte
 start:
 'using inverted baudrate to communicate with the
 'HT through a 440 ohm on the TX and a
 '22K ohm on the RX Pins
 'let it warm up .1sec
 Pause 100
 Serout XBO,N9600,["Starting UART.....",10,13]
 loop:
 Serout XBO,N9600,["Query the xbee module....",10,13]
 Serout HTO,T2400,[$05,$01,$05,$02,$08,$04 ]
 Serin HTI,T2400,[b0,b1,b2,b3,b4,b5,b6,b7]
 'Hangs here........
 Serout XBO,N9600,["Retry"]
 Serout XBO,N9600,["Reply from XBEE...",10,13]
 Serout XBO,N9600,[#b0,#b1,#b2,#b3,#b4,#b5,#b6,#b7]
 Serout XBO,N9600,[10,13]
 Serout XBO,N9600,["That is all folks",10,13]
 Pause 1000 'pause 1 sec
 Goto loop ''endless loop
 I am stumped.... any help would be greatly appreciated.
 Thank you,
 oni
		Re: PIC hanging on Serin
		onioni, using your scope, what is the level at the PIC rx pin when the system is in an idle mode (no data being sent)
		Hi Dave,
 I am running the 3.3V TX output through 2 inverters then to the RX pin of the PIC, so the PIC RX pin is seeing +5V when nothing is being sent.
 onioni
		onioni, That sounds good to me. Looking at the scope, is the timing correct for the baudrate? Try sending repeatedly the character "w" I beleive which should what looks a square wave. See if the time interval for the HIGH and the LOW are the same. If there is a difference this may be due to a slewrate problem with the inverters.
		I checked the waveforms on the scope and the are identical except the one from the inverter is 5V instead of 3.3V.   No differences due to slew rate to speak of.  I have read on this forum that it is important to read the PIC datasheet, well I just learned a hard lesson.  By properly setting the CMCON0 register to allow digital I/O, the program worked like a charm.  I found this out after switching the 3.3V input-output with those of the hyperterminal.  The HT was then hanging instead of the 3.3V chip.  I will read the datasheet more closely next time.  I appreciate you taking the time to troubleshoot with me.
 onioni
