Just throwing in my 10 cents here. Instead of changing the defaults in the PBP file, just make a seperate file with the configs you want. It can be a 1 line file with just
__config yada yada yada
then "INCLUDE" the file in your programs. There are 2 reasons I suggest this. First is if you change the PBP file, then upgrade later, all your changes are lost. Second It is a simple matter to change your include file for different setups like now you want to use internal osc and so forth. Also it is much easier to understand for YOU in a year or 2 what the configs were doing without having to track down the .inc and read it.
