Any PICBASIC codes that demonstrate the use of multiple timers for 16F628A ?
16F628A Datasheet:
Timers 2 x 8-bit, 1 x 16-bit
How do you use those multiple timers in PICBasic ?
I would like to run two LED chaser sequence [5 LEDs each] but they are to be played out in different speeds.
I think using the 2 eight bit timers would be nice [I am assuming here that they are completely independent of each other.]
Actually I don't even mind using the 16 bit timer too if it is necessary, I just need it to work.*
The longer LED chaser sequence of the two will have a pause of say 100 [PICBASIC: Pause 100] before the next LED lights up.
Is there any PICBASIC codes that demonstrate the use of multiple timers ?
Hopefully not too overly complicated as I am just trying to flash some LEDs here.
Re: Any PICBASIC codes that demonstrate the use of multiple timers for 16F628A ?
