Receiving (Relatively) High Speed Serial Data
Greetings,
I'm in the beginning stages of a project where one master PIC (likely a 16F88 @ 20 MHz) will be sending serial data to a string of 20-30 12F629s.
The smaller chips will be running on the internal oscillator @ 4 MHz. And no, they don't have a USART.
The repeating data stream will consist of a start character and 3-byte 'chunks' for each downstream PIC, ie
'*', 1A, 1B, 1C, 2A, 2B, 2C, 3A, 3B, 3C ... 29A, 29B, 29C
Each downstream PIC will be hard-programmed to listen only for data relating to its address, ie 1, 2 or 3... 29
My question:
How can I *reliably* get these downstream clockless wonders to receive data at speads greater than 9600 baud? I'd love for them to receive at 19,200 if I can pull it off.
This would let me update my data stream at a rate of 30 Hz or so...
Thoughts?
John
Re: Receiving (Relatively) High Speed Serial Data
Is it possible to Send/Receive data at 9600/19200 with 4MHz internal OSC?
