Using Pensol SL10, one cheap 12F675 and N3310 display, I made for myself this soldering station. Works fine, the mos-fet remains cool, but... I wonder if my code it's the better way to drive the mos-fet and keep most accurate temperature of iron ("pwm mosfet, 255, 300").
Any advice it's wellcome ! Thanks in advance !
Code:'===============================================================================
'* Statie digitala de lipit, cu display de NOKIA 3310 *
'* Digital solering station with N3310 display *
'* by Dan Niculescu, june 2011 *
@ DEVICE PIC12F675, intrc_osc_noclkout, wdt_off, mclr_off
DEFINE ADC_BITS 10
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
CMCON = 7
TRISIO = %001001
INTCON = 0
GPIO = 0
ANSEL = %00010001
ADCON0 = %10000001
wpu = %00000010
D_C var GPIO.2
SDIN var GPIO.4
SCK var GPIO.5
MOSFET var GPIO.1
buton var GPIO.3
LcdReg var byte
x var byte
y var byte
z var byte
a var byte
PosX var byte
PosY var byte
Chr var byte
LcdData var byte
Offset var byte
Char var byte
adval var word
w1 var word
vt var word
cnt var byte
grup var word
mode var byte
calibra var word
i var byte
DATA @0,$3E,$51,$49,$45,$3E,_ ' 0
$00,$42,$7F,$40,$00,_ ' 1
$42,$61,$51,$49,$46,_ ' 2
$21,$41,$45,$4B,$31,_ ' 3
$18,$14,$12,$7F,$10,_ ' 4
$27,$45,$45,$45,$39,_ ' 5
$3C,$4A,$49,$49,$30,_ ' 6
$01,$71,$09,$05,$03,_ ' 7
$36,$49,$49,$49,$36,_ ' 8
$06,$49,$49,$29,$1E,_ ' 9
$08,$08,$3E,$08,$08,_ ' +
$08,$08,$08,$08,$08,_ ' -
$00,$60,$60,$00,$00,_ ' .
$00,$02,$05,$02,$00,_ ' grad
$3E,$41,$41,$41,$22,_ ' C
$7F,$02,$0C,$02,$7F,_ ' M
$00,$00,$00,$00,$00,_ ' space
$08,$04,$7F,$04,$08,_ ' arrow up
$20,$40,$7F,$40,$20 ' arrow down
Low D_C 'Command/Data
LcdReg = %00100001 'LCD Extended Commands.
call PrintCtrlLcd
LcdReg = $FF 'Set LCD Vop (Contrast).Initial $C5
call PrintCtrlLcd
LcdReg = %00000110 'Set Temp coefficent.
call PrintCtrlLcd
LcdReg = %00010011 'LCD bias mode 1:48.
call PrintCtrlLcd
LcdReg = %00100000 'LCD Standard Commands
call PrintCtrlLcd
LcdReg = $0C 'LCD in normal mode. $0D inverse
call PrintCtrlLcd
Pause 100
Call CursorHome
Pause 100
Gosub LCD_Clear
mode = 0
Pause 500 ' time to give-up :)
'===================== READING VOLTAGE ==============================
low mosfet
call Borderline
pause 50
vt=0
grup=0
for cnt = 1 to 20
ADCON0.1 = 1
WHILE ADCON0.1 = 1 : WEND
Pause 10
adval.HighByte = ADRESH
adval.LowByte = ADRESL
PAUSE 10
vt=adval * 500
vt=div32 1023
grup=vt+grup
PAUSE 10
next cnt
w1=grup / 20
'===================== setting cursor for display the voltage
LcdReg = %10000000 + 25 ' cursor X
call PrintCtrlLcd
LcdReg = %01000011 ' cursor Y
call PrintCtrlLcd
'===================== now display results
if (w1 dig 2) <1 then
char = 16
call Printchar
Char = (w1 dig 2)
call PrintChar
Char = (w1 dig 1)
call PrintChar
if (w1 dig 0) < 5 then
Char = 0
call PrintChar
char = 5
call PrintChar
Char = 16
call PrintChar
Char = 13
call PrintChar
Char = 14
call PrintChar
if buton = 0 then
mode = mode + 1
gosub memo
gosub check
Pause 100
Goto Main
'================== L C D ===========================================
CursorHome: LcdReg = %10000000 ' cursor Home
call PrintCtrlLcd
LcdReg = %01000000 ' cursor Home
call PrintCtrlLcd
PrintChar: offset = Char * 5
for a = 1 to 5
read offset, LcdReg
call PrintDataLcd
offset = offset + 1
next a
LcdReg = 0
call PrintDataLcd
PrintCtrlLcd: D_C = 0
PrintDataLcd: for x = 1 to 8
SDIN = LcdReg.7
SCK = 1
LcdReg = LcdReg << 1
SCK = 0
next x
D_C = 1
LCD_Clear:
PosX=0:PosY=0:Gosub LCD_GotoXY
D_C = 1
FOR Chr=1 TO 252
LcdData=0:Gosub LCD_ByteOut
next Chr
LCD_GotoXY:
D_C = 0
LcdData=%01000000 | PosY :Gosub LCD_ByteOut
LcdData=%10000000 | PosX :Gosub LCD_ByteOut
LCD_ByteOut:
SHIFTOUT SDIN,SCK,1,[LcdData]
GotoXY:
LcdReg = %01000000 | Posy : call PrintCtrlLcd 'Y
LcdReg = %10000000 | Posx : call PrintCtrlLcd 'X
memo:
if mode = 1 then
gosub poz
char = 17
call PrintChar
calibra = 4800
if mode = 2 then
gosub poz
char = 15
call PrintChar
calibra = vt
if mode = 3 then
gosub poz
char = 18
call printchar
calibra = 10
if mode > 3 then
mode = 0
gosub poz
char = 16
call printchar
check:
if mode >= 1 then
if w1 < (calibra-2) then pwm mosfet, 255, 300
low mosfet
Poz:
LcdReg = %10000000 + 67 ' cursor X
call PrintCtrlLcd
call PrintCtrlLcd
BorderLine:
'=================================== RAW UP
LcdReg = %10000000 ' cursor X
call PrintCtrlLcd
LcdReg = %01000000 ' cursor Y
call PrintCtrlLcd
for y = 0 to 83
LOokup y, [$FF,$01,$01,$01,$01,_
$01,$01,$01,$01,$01,$01,$01,$01,$01,$FD,$FD,$FD,$85,$85,$FD,$FD,$79,_ 'D
$01,$01,$FD,$FD,$FD,$01,$01,$79,$FD,$FD,$85,$A5,$ED,$ED,$69,$01,$01,_ 'IG
$FD,$FD,$FD,$01,$05,$05,$05,$FD,$FD,$FD,$05,$05,$05,$01,_ 'IT
$F9,$FD,$FD,$25,$25,$FD,$FD,$F9,$01,$01,$FD,$FD,$FD,$81,$81,$81,$81,_ 'AL
$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$FF] ,LcdReg
call PrintDataLcd
next y
'=================================== RAW 1 to 4
for i= 1 to 4
posx=0
posy=i
gosub GotoXY
lcdReg= $FF
call PrintDataLcd
next i
for i = 1 to 4
posx=83
posy=i
gosub GotoXY
lcdReg= $FF
call PrintDataLcd
next i
'=================================== RAW DOWN
LcdReg = %10000000
call PrintCtrlLcd
LcdReg = %01000101
call PrintCtrlLcd
for y = 0 to 83
LOokup y, [$FF,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
$80,$80,$80,$80,$80,$80,$80,$80,$FF] ,LcdReg
call PrintDataLcd
next y
End 'of program
