PBP array in ASM statements
I have defined a variable Counters VAR BYTE [4] bankA, and I'm using it in ISR.
Instead Counters[0] = Counters[0] +1, I want to use @ INCF _Counters, F because it is faster.
This is for first byte in array
@ INCF _Counters, F
and it works.
For the second byte in array I tried this:
@ INCF _Counters+1, F
But does not work, if I use Counters[1] = Counters[1] +1 then it works.
How to fix that?
Re: PBP array in ASM statements
...nevermind... keep thinking...
The same is happening with @ CLRF _Counter +1.
And ISR stops, sometimes begins to run, sometimes I have to reset my pic:confused:
I'm tad rusty, for ease... I would bet your should assign your array to BANK0 instead...
post your PIC model and code, we'll try to help
Here it is ISR
if PIR2.1=1 then
T3CON=%00000110
Wp= Wp & uwp
Xn.0=IN1
Xn.1=IN2
IF (Xn.0<Xs.0 AND Trf=0) OR (Xn.0<Xs.0 AND Xn.1=1 AND Trf=1) THEN
@ INCF _Counter,F 'this work
IF Counter[0] = Mtp2[0] OR (Counter=256 AND Mtp2[0]=0)THEN
@ CLRF _Counter ' and this
CNT[0]=CNT[0] + Add[0]
IF (Xn.1<Xs.1 AND Trf=0) OR (Xn.0<Xs.0 AND Trf=1 AND Xn.1=0) THEN
@ INCF _Counter+1,F 'Counter[1] = Counter[1] + 1 'won't work
IF Counter[1] = Mtp2[1] OR (Counter[1]=256 AND Mtp2[1]=0)THEN
@ CLRF _Counter+1'Counter[1]=0 'won't work
CNT[1]=CNT[1]+Add[1]
Xs=Xn
@ CLRF PIR2
Pic is 18LF14K50
EDIT:
bank0 or bankA is same...
I tried RTC,it works fine with both.
weird... a simple loop works here,
start:
asm
incf _MyArray,F
incf _MyArray+1,F
endasm
myvar=myarray[0]
myvar2=myarray[1]
goto start
but as you're using a blend mix of ASM and PBP in an ISR, you must make sure you're always on the good BANK case not, hell yeah it may goes to lalaland... what you could try is to set all variable that goes in the ISR to BANKA.
And yes I know I miss something ;)
EDIT: The more I think, the more it looks like a bank switching issue,
MyArray VAR BYTE[8] BANK1
MyVar var byte BANK0
MyVar2 var byte BANK0
clear
start:
asm
CHK?RP _MyArray
incf _MyArray,F
incf _MyArray+1,F
endasm
myvar=myarray[0]
myvar2=myarray[1]
goto start
The above work... commentout the CHK?RP line.. and nope... it doesn't.
And NOPE, BANK0 !=BANKA
BANKA $0000, $005F
BANK0 $0060, $00FF
Finger crossed before the real ASM/Compiler gurus came here and slap me a good one :eek:
As you can see, my isr have both and asm and pbp... All variables is in bankA.
Somewhere i read that bank for 18F doesn't matter...
How to setup correctly banks?
But if I use i = i +1 instead INCF everything works. INCF and CLRF work if I make a array to separate variables...
Since we don't have the full code, or .LST file, I'll leave the more in deep & technical explanation of Access Ram, BSR and plah plah plah of section 3.3.3 to better guys (I hope I'm right though ;)).
Again, the compiler keep track of everything for you, hence why the PBP lines will always works.
add
@ CHK?RP _Counter
just before your INCF, DECF and or CLRF to see what happen
Are all of your variables in the same bank?
Same thing...
Here it's complite code
DEFINE OSC 4 ' We're using a 10MHz oscillator
Define INTHAND myint ' Define interrupt handler
DEFINE HSER_BAUD 2400
OSCCON=%01010110
OSCCON2.2=0
OSCTUNE.7=1
OSCTUNE.6=1
REFCON0=0
REFCON1=0
ADCON1=0
ADCON2=0
ANSEL =0
ANSELH=0
CM1CON0=0
CM2CON0=0
SRCON0=0
SRCON1=0
WPUA=0
WPUB=0
WDTCON=0
SLRCON=0
RCON.7=0
RCON.6=0
UCON=0
IOCA=0
IOCB=0
T0CON=0
T1CON=%00001111
T2CON=0
T3CON=%00000110
INTCON=192
INTCON2=0
INTCON3=0
PIR1=0
PIR2=0
PIE1=1
PIE2=2
IPR1=0
IPR2=0
porta=0
portb=0
portc=0
trisa=255
trisb=255
trisc=255
'RTC_________________________
Seconds VAR BYTE bankA ' variables within myint must be in bank 0.
Minutes VAR Byte bankA ' Elapsed minutes
Hours var byte bankA
Day var byte bankA
Month var byte bankA
Year var byte bankA
Ticks var byte bankA
DMonth var byte bankA
'IO________________
SYMBOL Ul1 =PORTB.5
SYMBOL Ul2 =PORTB.6
SYMBOL Pull =PORTC.4
SYMBOL UWp =PORTC.3
'TRIS______________
INPUT Ul1
INPUT Ul2
OUTPUT Pull
INPUT uwp
'Brojaci___________
Brojac VAR LONG[3] bankA
PomBroj VAR WORD[2] bankA
Mtp1 VAR BYTE[2] bankA
Mtp2 VAR BYTE[2] bankA
Add VAR BYTE[2] bankA
Xn VAR BYTE bankA
Xs VAR BYTE bankA
Wp VAR BIT bankA
Trf var byte bankA
year=0
month=0
day=0
hours = 4
minutes = 0 ' Pre Set time here then add seconds to clock using button
seconds = 0
ticks=0
PomBroj[0]=0
PomBroj[1]=0
Brojac[0]=0
Brojac[1]=0
mtp1[0]=1
mtp1[1]=1
mtp2[0]=1
mtp2[1]=1
add[0]=1
add[1]=1
Trf=0
GoTo mainloop
@myint
If PIR1.0 =1 then
TMR1H=252
@ INCF _Ticks,F
if ticks=32 then
@ INCF _Seconds,F
@ CLRF _Ticks
if seconds > 59 then
@ CLRF _Seconds
@ INCF _Minutes,F
if minutes > 59 then
@ CLRF _Minutes
@ INCF _Hours,F
if hours > 23 then
@ CLRF _Hours
@ INCF _Day,F
If month=2 then
If year//4<>0 then
DMonth=29
DMonth=28
Dmonth=30+month.0
If day>Dmonth then
@ CLRF _Day
@ INCF _Month,F
If month>12 then
@ CLRF _Month
@ INCF _Year,F
if year>99 then year=0
Pull=1
TMR3H=255
TMR3L=207
T3CON=%00000111
@ CLRF PIR1
if PIR2.1=1 then
T3CON=%00000110
Wp= Wp & uwp
Xn.0=ul1
Xn.1=ul2
Pull=0
@ INCF _PomBroj,F 'PomBroj[0] = PomBroj[0] + 1
IF PomBroj[0] = Mtp2[0] OR (PomBroj=256 AND Mtp2[0]=0)THEN
Brojac[0]=Brojac[0] + Add[0]
@ CLRF _PomBroj'PomBroj[0]=0
PomBroj[1] = PomBroj[1] + 1 ' @ INCF _PomBroj+1,F '
IF PomBroj[1] = Mtp2[1] OR (PomBroj[1]=256 AND Mtp2[1]=0)THEN
Brojac[1]=Brojac[1]+Add[1]
@ CHK?RP _PomBroj
@ CLRF _PomBroj+1'PomBroj[1]=0'
Xs=Xn
@ CLRF PIR2
@ retfie FAST
mainloop:
if ticks = 0 then
trisb.7=0
hserout ["B1: ",dec9 brojac[0]," B2: ",dec9 brojac[1],13,10]'["Time: ",DEC hours, ":", DEC2 minutes, ":", DEC2 seconds,13,10]
GoTo mainloop
If i don't use PBP for clearing and increment variable here
@ CHK?RP _PomBroj
Counter(Brojac) Is incremented only on first falling edge. If I use PBP, everything work fine, but code is larger for 6 bytes. I need 4 counter. Becouse device have cr3203 batery, I'm trying to make smallest possible code. Maybe I can save on space by removing or's from IF's.
STOP THE PRESS! your problem is right here
In theory, this is valid only for 100% Assembler ISR.
Check for ON INTERRUPT or Darrel Taylor's INST interrupts (http://www.pbpgroup.com/modules/wfse...p?articleid=19)
Hm...
I did not know ...
I've seen in the example for the RTC, so I assume...
I will try dt_int...
By the way banksel isn't help either.
Thank you very much:)
BANKSEL is an MPASM directive, and PBP compiler doesn't keep track of it.
CHK?RP is an equivalent Macro to use with PBP.
I tried, but problem stays....
Maybe with DT_int will work.
I will test now, and come back with the results.
Same with DT_INT...
INCLUDE "DT_INTS-18.bas" ; Base Interrupt System
INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts
INT_Handler TMR1_INT, _RTC, PBP, yes
INT_Handler TMR3_INT, _CNT, PBP, yes
'Define INTHAND myint ' Define interrupt handler
OSCCON=%01010110
OSCCON2.2=0
OSCTUNE.7=1
OSCTUNE.6=1
REFCON0=0
REFCON1=0
ADCON1=0
ADCON2=0
ANSEL =0
ANSELH=0
CM1CON0=0
CM2CON0=0
SRCON0=0
SRCON1=0
WPUA=0
WPUB=0
WDTCON=0
SLRCON=0
RCON.7=0
RCON.6=0
UCON=0
IOCA=0
IOCB=0
T0CON=0
T1CON=%00001111
T2CON=0
T3CON=%00000110
INTCON=192
INTCON2=0
INTCON3=0
PIR1=0
PIR2=0
PIE1=1
PIE2=2
IPR1=0
IPR2=0
porta=0
portb=0
portc=0
trisa=255
trisb=255
trisc=255
Day var byte bankA
Year var byte bankA
'IO________________
SYMBOL Ul1 =PORTB.5
SYMBOL Ul2 =PORTB.6
SYMBOL UWp =PORTC.3
'TRIS______________
INPUT Ul1
INPUT Ul2
OUTPUT Pull
INPUT uwp
'Brojaci___________
Xn VAR BYTE bankA
Xs VAR BYTE bankA
Wp VAR BIT bankA
Trf VAR BIT bankA
Smpl VAR BIT bankA
year=0
month=0
day=0
hours = 4
seconds = 0
ticks=0
smpl=0
PomBroj[0]=0
PomBroj[1]=0
Brojac[0]=0
Brojac[1]=0
mtp1[0]=1
mtp1[1]=1
mtp2[0]=1
mtp2[1]=1
add[0]=1
add[1]=1
Trf=0
@ INT_ENABLE TMR3_INT
@ INT_ENABLE TMR1_INT
GoTo mainloop ' jump over the interrupt handler and sub
RTC:
TMR1H=252
@ INCF _Ticks,F
if ticks=32 then
@ INCF _Seconds,F
@ CLRF _Ticks
@ CLRF _Seconds
@ INCF _Minutes,F
@ CLRF _Minutes
@ INCF _Hours,F
if hours > 23 then
@ CLRF _Hours
@ INCF _Day,F
If month=2 then
If year//4<>0 then
DMonth=29
DMonth=28
Dmonth=30+month.0
If day>Dmonth then
@ CLRF _Day
@ INCF _Month,F
If month>12 then
@ CLRF _Month
@ INCF _Year,F
Pull=1
TMR3H=255
IF Smpl=1 then
TMR3L=207
TMR3L=240
T3CON=%00000111
@ INT_RETURN
CNT:
T3CON=%00000110
Wp= Wp & uwp
Xn.0=ul1
Xn.1=ul2
Pull=0
@ CLRF _PomBroj+1 'PomBroj[1]=0
Xs=Xn
@ INT_RETURN
mainloop:
if ticks = 0 then
trisb.7=0
' 2 portb.7,84,
GoTo mainloop ' Repeat main loop
Edit:
With the DT_INT code is twice bigger than it was. Maybe I could try to get rid of arrays.
But it complicates the rest of my code... But on the other hand we will slightly extend the battery life...
It is likely when you enter your ISR, BSR is not 0. You can use PBP stuff in your ASM interrupt as long as you don't use any PBP stuff that uses system variables. These are things like serin/out, adcin, debug etc.
The thing you MUST do when you first enter is BSR =0. Doesn't matter if you have all ASM or a mix. PBP assumes it is set to bank 0, when it needs a different bank, it will change to it, then change back when done that command. When your interrupt occurs, you may be in a different bank. Then none of you interrupt stuff will work correct. In fact, you may not even be able to clear the interrupt flag.
This MAY not be the problem right now, but it will be. I spent 2 weeks trying to figure this out. Since then my interrupts work great! Give this a try.
Now no need to worry if using on interrupt or DT_INT.
I know that I can't use any PBP stuff that uses system variables. In myint I'm only using PBP If's and basic math function...
Now I'm back to Define INTHAND. And I added BSR = 0 after @myint
I didn't know how pbp handle banks. Thank you for your notification :)
Is there need to return to the bank where he was?
eg:
@myint
BSR_Save=BSR
BSR=0
ISR routine
BSR=BSR_Save
If you are using 1 of the cool autocontex saving chips (interrupt section of the datasheet) BSR should be one of the registers saved and restored. If not, add it in to where you save w, status, and pcl. Then restore it with them.
From datasheet:
During interrupts, the return PC address is saved on
the stack. Additionally, the WREG, STATUS and BSR
registers are saved on the fast return stack.
I have not thought before I asked that... Sorry...
But I still can not find what causes problemon CLRF and INCF:confused:
Ok...
Let say that PomBroj is WORD not byte:eek::eek:
And i figure out reading .asm file... I need glasses!
Thanks everybody.
