Random number -> Corresponding LED lit (n00besque content contained)
(& I'd search but I don't know what the search terms would be!)
Ok, I have six LEDs, declared like thus...
LED1 var PortC.0
LED2 var PortA.1
LED3 var PortA.2
LED4 var PortC.5
LED5 var PortA.4
LED6 var PortA.5
I want to get the LEDs to light randomly, so I'm gonna do a 6 number random number generator, ie something like this...
MyWord var Word
MyByte var Byte
Random MyWord
MyByte=(MyWord//6)+1
which, if I've plagiarized correctly, should result in random number between 1 & 6..... *but* how do I get the result of the random number generator mapped to a corresponding led? (therefore if the random number is 3, I want LED3 to light up, if the random number is 6, then I want LED6 to light etc).
Many thanks
Re: Random number -> Corresponding LED lit (n00besque content contained)
Darrel Taylor
LED1 = !(MyByte != 1)
LED2 = !(MyByte != 2)
LED3 = !(MyByte != 3)
LED4 = !(MyByte != 4)
LED5 = !(MyByte != 5)
LED6 = !(MyByte != 6)
Excellent, the top of my fishing rod is moving a touch!
but I don't understand the response!
eg if the random number comes out as 1, meaning I want to light LED1.....normally - if wanting to light LED1 for 200ms, I'd simply do this....
HIGH LED1
PAUSE 200
LOW LED1
PAUSE 200
but, how do I do this......
HIGH LED'result_of_random_number'
PAUSE 200
LOW LED'result_of_random_number'
PAUSE 200
Apologies if that is what you just told me Darrel, but I'm not sure how to use the info you gave me (that'll be the n00bishness that's never far away from all I do!)
Hey Darrel...that works a treat ...I've now got pretty twinkly Blue leds randomly flashing before my eyes (which strangely, makes me feel warm inside).
I note that a fair few of the random numbers are the same as the previous (I guess when you've only six to choose from, then that's bound to happen!), so I'll sit down for a few weeks & try & code this out!
Many thanks!
Hank.
Edit: Actually, dialing out the successive repeats only took a couple of minutes...
MyWord var Word
MyByte var Byte
previous_random var Byte
Random MyWord
if previous_random = MyByte then goto Main
GOSUB HIGH_LED
PAUSE 50
GOSUB LOW_LED
PAUSE 50
GOTO Main
HIGH_LED:
SELECT CASE MyByte
CASE 1 : HIGH LED1
CASE 2 : HIGH LED2
CASE 3 : HIGH LED3
CASE 4 : HIGH LED4
CASE 5 : HIGH LED5
CASE 6 : HIGH LED6
END SELECT
LOW_LED:
SELECT CASE MyByte
CASE 1 : LOW LED1
CASE 2 : LOW LED2
CASE 3 : LOW LED3
CASE 4 : LOW LED4
CASE 5 : LOW LED5
CASE 6 : LOW LED6
END SELECT
Just had a sleep on this - I've never previously used case, and now I fresh look at it, to my eyes it's just a load of IFs?
For example....
HIGH_LED:
SELECT CASE MyByte
CASE 1 : HIGH LED1
CASE 2 : HIGH LED2
CASE 3 : HIGH LED3
CASE 4 : HIGH LED4
CASE 5 : HIGH LED5
CASE 6 : HIGH LED6
END SELECT
could be written as...
IF MYBYTE = 1 THEN HIGH LED1
IF MYBYTE = 2 THEN HIGH LED2
IF MYBYTE = 3 THEN HIGH LED3
IF MYBYTE = 4 THEN HIGH LED4
IF MYBYTE = 5 THEN HIGH LED5
IF MYBYTE = 6 THEN HIGH LED6
So when to use case & when to use if?
Going back 20 years to when I used to write simple VMS DCL programs, I could construct code like thus...
HIGH "LED"+'MyByte'
the stuff inbetween " " was text & stuff in the ' ' was the value held in a variable
therefore the above would actually run as.....
HIGH LED1 (assuming MyByte held 1) ......presumably no similar ways of constucting in Picbasic?
Select Case is a lot like a "Load of IF's" with a few differences.- It removes some of the (n00besque content contained) look and feel. :)
- Only the first "CASE" that evaluates TRUE will execute, then it exits the SELECT block.
In your list of IF's, if the first one is true, it still goes on and evaluates all the other IF's too.
This allows more complex logic, where more than one test can be true, but only the first one is acted on.
The same functionality using IF statements would look like this ...
IF MYBYTE = 1 THEN
HIGH LED1
IF MYBYTE = 2 THEN
HIGH LED2
IF MYBYTE = 3 THEN
HIGH LED3
IF MYBYTE = 4 THEN
HIGH LED4
IF MYBYTE = 5 THEN
HIGH LED5
IF MYBYTE = 6 THEN
HIGH LED6
OR, if you have PBP 2.60 you could do it like this ...
IF MYBYTE = 1 THEN
HIGH LED1
ELSEIF MYBYTE = 2 THEN
HIGH LED2
ELSEIF MYBYTE = 3 THEN
HIGH LED3
ELSEIF MYBYTE = 4 THEN
HIGH LED4
ELSEIF MYBYTE = 5 THEN
HIGH LED5
ELSEIF MYBYTE = 6 THEN
HIGH LED6
It may not seem like much difference with this simple example, but with large SELECT CASE blocks using more complex comparisons, it can save a boat load of execution time not having to evaluate every condition.
* SELECT CASE is also much easier to read. Especially when it's not your program.
PicBasic Pro, was written to generate the Smallest and Fastest code possible. As it is the HIGH/LOW statements only use a couple of instruction cycles. If you add in the abilities to use them like array's and access pins non-contiguously, it would make EVERY HIGH/LOW statement Bigger and Slower, breaking everyone's code, and causing more complaints than not having those abilities produces.
Many thanks Darrel....crystal clear now :)
I've tried to randomize 20 LEDs hooked up as shown in the attachment with the following code:
(Sorry, I've had to retype it. Long story.)
clear
define osc4
ansel=0
comcon0=7
adcon0=0
delay var word
myword var word
mybyte var byte
previous_random var byte
gpiostate var byte
tristate var byte
delay = 250
random myword
mybyte = (myword//20)
if previous_random = mybyte then goto main
gosub high_led
pause delay
gpio = %000000
pause delay
previous_random= mybyte
high led:
lookup mybyte,[%000001, etc for 20 LEDs], gpiostate
gpio = gpiostate
lookup mybyte,[%111100, etc for 20 LEDs], tristate
trisio = tristate
The problem I'm having is two fold.
First, LED0 never lights. I've watched it for a about 3 minutes several times and that first LED never lights. Any ideas why?
Secondly, although I implement the previous_random scheme shown previously in the thread, I often get an LED that will light repeatedly before moving on. Any ideas why?
As always, most of your thoughts are appreciated.
We really need to see the entire code esp. the lookup tables.
It worked perfectly for me ....any reason you have not copied the code verbatim?
Re LED1 never lighting, what happens if you comment out the random aspect & simple make mybyte = 1 (where 1 is the LED you're not seeing lighting up etc)...this should light the suspect LED up all the time & proves both the wiring/LED at least.
Re the same LED lighting in succession, I'd approach this by getting some debug/hserout info of 'mybyte' onscreen....else you're grasping in the dark. (no pun intended!)
I did run another program to ensure all the LEDs are hooked up and working. They all work using the cut and pasted look up tables provided.
Hank, when you say it worked perfectly did you use the schematic I provided? The last time I chased a problem with these LEDs, it turned out to be the circuit not the code. If you look here http://www.picbasic.co.uk/forum/show...ght=wood+chuck you'll see what I mean.
Here are the look up tables.
lookup mybyte,[%000001, %000010, %000001, %000100, %000001, %010000, %000001, %100000, %000010, %000100, %000010, %010000, %000010, %100000, %000100, %010000, %000100, %100000, %010000, %100000], gpiostate
gpio= gpiostate
lookup mybyte,[%111110, %111100, %111010, %111010, %101110, %101110, %011110, %011110, %111001, %111001, %101101, %101101, %011101, %011101, %101011, %101011, %011011, %011011, %001111, %001111],tristate
trisio= tristate
I don't currently have the knowledge to display my number on screen but if the LED is lit by another program, proving it does work, then looking at a number will only tell me that the LEDs number never comes up.
I wonder if someone could explain the
"MyByte=(MyWord//6)+1" part? // = Remainder (Modulus)? It isn't clear to me what this is doing and how it is extracting the 6 variables.
I need to randomize 8 LEDs and would like to understand it better.
Bo
If you do the math with a calculator you'll, in my opinion, never understand modulus. Use paper and pencil for some small numbers and you'll see how modulus works.
I believe to randomize 8 LEDs all you need to do is change the 6 to an 8. Like
Random myword
mybyte=(myword//8)
Depending on how you use mybyte depends on whether or not you need to +1 after myword//8.
I'm sure someone will chime in and say I've messed up but there you have it.
