Trying to resolving 6 Compiler Errors
Hi All,
I am working with code written by another person and being new there are complier errors I am not sure how to resolve. I did post the questions under another title and there have been no answers so I thought maybe I would try here.
Line 62 has: high presspwr there is no pin defined as presspwr which pin should be used?
Line 195 has: d[17] = temp2.byte0 There is no array named d and I have never defined an array
Line 196 has: d[18] = temp2.byte1 '
Line 133 has: high pgc there is no pin defined as pgc which pin should be used?
Line 220 has: gosub shutdownmemory there is no sub-routine with this name
Line 221 has: gosub lowestpower there is no sub-routine with this name either end
My guess is these 2 lines should be deleted and a new line added that says gosub resetintersema so the program will continue to run without stopping?
Thanks to any and all who are willing to help and comment.
Best, Ed
Device is a 18F4610
1. '***************** Defines *****************************
2.
3. DEFINE OSC 20 'Define crystal frequency
4. DEFINE DEBUG_REG PORTB 'Debug output pin port
5. DEFINE DEBUG_BIT 6 'Debug output pin bit
6. DEFINE DEBUG_BAUD 19200 'Debug baud rate
7. DEFINE DEBUG_MODE 0 'Debug mode: 0 = True, 1 = Inverted
8.
9.
10. '**************** Intersema Variables ***********************
11. C1 var word ' 5540 Pressure sensitivity
12. C2 var word ' 5540 Pressure Offset
13. C3 var word ' 5540 Temp Coef of pressure sensitivity
14. C4 var word ' 5540 Temp Coef of Pressure Offset
15. C5 var word ' 5540 Reference temperature
16. C6 var word ' 5540 temp coef of Temp reading
17. ' C1 to C6 are in EEROM as VAL.byte0, VAL.byte1 from 108 to 159
18. D1 var word ' raw pressure word from Intersema sensor
19. D2 var word ' raw temperature word
20. D1Flag var bit
21. W1 var word ' coefficient from 5540
22. W2 var word ' coefficient from 5540
23. W3 var word ' coefficient from 5540
24. W4 var word ' coefficient from 5540
25. ' W1 to W4 are NOT stored in EEROM - they are not needed again.
26. dT var long ' intermediate calc value
27. dT1 var long ' intermediate calc value
28. dT2 var long
29. UT1 var word ' Calibration temperature
30. II var byte 'used ONLY within Intersema routines
31. IJ var byte
32. IK var byte
33. IL var byte
34. ILoop var word
35. CalFlag var bit 'EEROM 99. Used to reduce wear on EEROM
36.
37. 'General purpose Intersema and DS1629 RTC/Temperature variables
38. ClkChk var word '= 8192 if IntRC clock is exactly on frequency
39. TimeFlag var bit
40. TempRead var word
41. CntRem var word
42. CntPerC var word
43.
44. IW var long
45. IX var long
46. IY var long
47. IZ var long
48.
49. T2 var long 'Second order Temperature correction
50. P2 var long 'Second order Pressure correction
51. Offset var long
52. Senstvty var long
53. Pressure var long '
54. Celsius var long 'a LONG allows negative temperatures
55.
56. goto endofsubroutines ' jump subroutines at startup
57. '******************* Subroutines ***********************
58.
59. ResetIntersema:
60. ' need 32768 @ 50% for Intersema on CCP2.
61. TRISB = %10000001 : TRISD.7 = 0 'DIn, DOut & SClk
62. high presspwr : pause 100 : hpwm 2, 127, 32767 : pause 50
63. shiftout din, sclk, 0, [85, 85, 0\5] ' Sense of Din is IN to 5541
64. pauseus 100
65. return
66.
67. FetchWord:
68. shiftin dout, sclk, 2, [ij, ii, ik\1]
69. 'IJ is hi byte, II is lo byte, IK is a dummy and discarded
70. return
71.
72. CalSensor:
73. read 99, calflag : if calflag = 1 then calsensordone
74. debug 13, 10, "Fetch Intersema data", 13, 10
75. ' This fetches and unpacks the factory calibration coefficients
76. ' from W1 ~ W4. W values need not be stored.
77. ' These bitmaps are unpacked into the 6 working coefficients
78. ' C1 to C6 which must be stored in EEROM for later use.
79. 'W1
80. gosub resetintersema
81. shiftout din, sclk, 0, [87, 1\5] ' Send W1 pattern to all sensors
82. gosub fetchword ' get reply
83. W1.byte0 = ii
84. W1.byte1 = ij
85.
86. 'W2
87. gosub resetintersema
88. shiftout din, sclk, 0, [215, 0\5] ' Send W2 pattern
89. gosub fetchword
90. W2.byte0 = ii
91. W2.byte1 = ij
92.
93. 'W3
94. gosub resetintersema
95. shiftout din, sclk, 0, [55, 1\5] ' Send W3 pattern
96. gosub fetchword
97. W3.byte0 = ii
98. W3.byte1 = ij
99.
100. 'W4
101. gosub resetintersema
102. shiftout din, sclk, 0, [183, 0\5] ' Send W4 pattern
103. gosub fetchword
104. W4.byte0 = ii
105. W4.byte1 = ij
106.
107. 'Unpack W1 ~ W4 into C1 ~ C6 coefficients
108. 'C1
109. C1 = W1 >> 3
110. write 108, c1.byte0
111. write 109, c1.byte1
112. 'C2
113. C2 = ((W1 & %0000000000000111) << 10) + (W2 >> 6)
114. write 110, c2.byte0
115. write 111, c2.byte1
116. 'C3
117. C3 = W3 >> 6
118. write 112, c3.byte0
119. write 113, c3.byte1
120. 'C4
121. C4 = W4 >> 7
122. write 114, c4.byte0
123. write 115, c4.byte1
124. 'C5
125. C5 = ((W2 & %0000000000111111) << 6) + (W3 & %0000000000111111)
126. write 116, c5.byte0
127. write 117, c5.byte1
128. 'C6
129. C6 = W4 & %0000000001111111
130. write 118, c6.byte0
131. write 119, c6.byte1
132.
133. ' high pgc : pause 1
134. ' debug "Intersema Factory data ", $0D, $0A, "W1 = ,"_
135. ' , #w1, ", W2 = ,", #w2, ", W3 = ,", #w3, ", W4 = ,", #w4, $0D, $0A
136. ' debug "Derived coefficients", $0D, $0A, "C1 = ,", #C1, ", C2 = ,", #C2,_
137. ' ", C3 = ,", #C3, ", C4 = ,", #c4, ", C5 = ,", #C5, ", C6 = ,", #C6.byte0,_
138. ' $0D, $0A
139.
140. ' read 99, calflag : if calflag = 0 then write 99, 1
141. CalSensorDone:
142. return
143.
144. ReadIntersema: '
145. ' D1 is Pressure - D2 is Temperature
146. ' Uses LONG datatype to handle negative temperatures
147. ' This routine reads the sensor and returns Pressure word
148. ' and Celsius long
149. ' A, II, IJ, W and X are all destroyed
150.
151. gosub resetintersema
152. 'D1
153. shiftout din, sclk, 0, [47, 0\5] ' Select D1 pattern
154. While dout = 1 : wend 'Convert5541Delay:
155. gosub fetchword
156. ' This returns ii = lobyte, ij = hibyte from the sensor
157. D1.byte0 = ii
158. D1.byte1 = ij
159. 'D2
160. shiftout din, sclk, 0, [79, 0\5] ' Select D2 pattern
161. While dout = 1 : wend
162. gosub fetchword
163. D2.byte0 = ii
164. D2.byte1 = ij
165.
166. CalcTempPress: '32 bit signed arithmetic version. Handles negatives.
167. read 108, c1.byte0
168. read 109, c1.byte1
169. read 110, c2.byte0
170. read 111, c2.byte1
171. read 112, c3.byte0
172. read 113, c3.byte1
173. read 114, c4.byte0
174. read 115, c4.byte1
175. read 116, c5.byte0
176. read 117, c5.byte1
177. read 118, c6.byte0
178.
179. 'formulae for DS5541 are NOT the same as for DS5540
180. ut1 = 8*c5 + 10000
181. dt = d2 - ut1
182. Celsius = 200 + dt*(c6 + 100)/2048
183. offset = c2 + ((c4 - 250)*dt)/4096 +10000
184. senstvty = c1/2 + ((c3 + 200)*dt)/8192 + 3000
185. pressure = (senstvty * (d1 - offset))/4096 + 1000
186.
187. 'NOT applying second order temperature correction in this
188. 'version.
189. 'Note 2nd order correction formula ambiguity in datasheet.
190.
191. if celsius < 0 then 'high bit of 32 bit number is set
192. temp2 = 1000 - celsius
193. else
194. temp2 = 1000 + celsius
195. d[17] = temp2.byte0
196. d[18] = temp2.byte1
197. endif
198. if calflag = 0 then
199. high pgc : pause 1
200. debug "MS5541 Celsius = ", sdec Celsius/10, ".", dec1 celsius//10, _
201. ", Pressure = ", dec pressure, " mBar, recorded as ",_
202. dec temp2, 13, 10
203. endif
204. return
205.
206.
207. EndOfSubRoutines:
208. '*********************** Initialise *******************
209.
210. FetchDepth:
211. gosub readintersema
212. 'debug "T2 = ", dec temp2, 13, 10
213. debug dec (temp2 - 1000)/10, ".", dec1 (temp2 - 1000)//10, _
214. ", ", #pressure, " mBar", 13, 10
215.
216. 'this returns Pressure & Celsius, both words.
217. hpwm 2, 0,0 'turn off Mclk
218.
219. ShutDown:
220. gosub shutdownmemory
221. gosub lowestpower
222. end
223.
Re: Trying to resolving 6 Compiler Errors
Your little problem is ... one or two pieces of code are missing :D
Hi Alain,
Of this I am certain and just need to know how to solve this as there is much I do not understand yet. :o
Ramius
Hi All,
Best, Ed
223.
Hi Ed,
as Alain stated, you are missing some code.
pick you pins for the pin errors
you NEED to Make the array, since you ARE using it
You need to make the missing sub routines and have them do what they need to do.
EDIT:
I retract the above, you need to copy code that works, I think if you get this to compile you will see stack overflows due to failure of the original code to return from subroutines, the subs flow into one another and subs calling subs without returns
Thanks Joe and you are right I just did not know what to choose. For some reason my cut and paste did not include this part:
Include "Modedefs.bas"
'********************* Declaired Pins **************************
Clk var PortD.2
Dout VAR PortD.3
Din var PortD.0
Sclk var PortC.3
Mclk var PortC.1
I do not believe the other subroutines are necessary as the hope is to have this run continuously. I have never done an array so I have no idea exactly how this is written. I will certainly look at the subs and returns and just trying to take this one step at a time.
Best, Ed
Here is a thread I started for array newbies, especially read the posts which ARE NOT mine. ;)
http://www.picbasic.co.uk/forum/showthread.php?t=8876
The example in this thread was written prior to PBP ver2.6 and as such the word Loop must be changed to something like MainLoop
or MyLoop as Loop is now a reserved word associated to DO.
The funniest thing in this thread ...
is to try to use READ and WRITE whith a pic that has NO EEPROM ...
:D:D
From what I've found to get " success 4304 bytes used " AND perfectly knowing it even can't run in real life ... :(
I gently suggest you to check your project from A to Z before coming back here ...
Acetronics
is to try to use READ and WRITE with a pic that has NO EEPROM ...
Details, Details, Details . . . Joe says with a sheepish grin . . . I wasn't paying such close attention . . .
