PBC equivelent to a VAR Overlay
I am converting a program from Bascom Basic to PBP. They have method of defining a VAR with a OVERLAY postscript.
Here is their definition of Overlay
OVERLAY
The OVERLAY option will not use any variable space. It will create a sort of phantom variable:
Dim x as Long at $60 'long uses 60,61,62 and 63 hex of SRAM
Dim b1 as Byte at $60 OVERLAY
Dim b2 as Byte at $61 OVERLAY
B1 and B2 are no real variables! They refer to a place in memory. In this case to &H60 and &H61. By assigning the phantom variable B1, you will write to memory location &H60 that is used by variable X.
So to define it better, OVERLAY does create a normal usable variable, but it will be stored at the specified memory location which could be already be occupied by another OVERLAY variable, or by a normal variable.
How would I go about translating this.
Re: PBC equivelent to a VAR Overlay
Section 4.4 in the manual....
x VAR LONG '32 bit variable - takes up actual RAM
b1 VAR x.BYTE0 'Alias to byte 0.
b2 VAR x.BYTE1
b3 VAR x.BYTE2
b4 VAR x.BYTE.3
w1 VAR x.WORD0 'Alias to the low word of x
w2 VAR x.WORD1 'Alias to the high word of x
Thanks Henrik
so to translate from
Dim MyVar As Byte At Buffer + &H01 Overlay
I would use
MyVar VAR Buffer.Byte$01
Thanks again
No, in that case and as long as Buffer is a WORD (2bytes) or a LONG (4bytes) you can use:
MyVar VAR Buffer.Byte1
If Buffer is an array of BYTES ie.
Buffer VAR BYTE[128]
Then you need to index that array, like:
MyVar1 VAR Buffer[0]
MyVar2 VAR Buffer[1]
MyVar3 VAR Buffer[75]
And so on.
Thanks Henrik
I got it.
