12f1822, PBP, EEPROM and pickit 2 = hex file too large
When I use the EEPROM keyword and load the file into pickit 2 I get an error message that the hex file is too large.
If i comment out the eeprom statement pickit 2 accepts it without fault.
If I then alter the EEPROM values using pickit 2 prior to programming the changes are still there when i read back from the pic with pickit 2.
Is there an error or a workaround i need to use to be able to add eeprom use on the 12f1822 with PBP ?
Chris
Re: 12f1822, PBP, EEPROM and pickit 2 = hex file too large
Good work ! Thanks for such a quick response.
Awesome
