Hello
I want to change a program for a 16F628 18F25J11 to resume
Bruce 18F25J11 RTCC program.
What are the changes to the registry level?
Can you help me
Thank you
Hello
Can you help me
Thank you
Hi, Jonas
After reading your question ...
I do think you better had posted it in French ...
I do not understand a bit about what you try to do ;)
Bonjour
Je voudrai adapter le programme de Bruce voir le lien
http://www.picbasic.co.uk/forum/showthread.php?t=12553
J’ai un programme a base de 628 qui gère un clavier matriciel et je
veux passer sur celui de Bruce afin d’utiliser le horloge (rtcc) interne du pic.
Merci
Hello
I will want to tailor the program to see the link Bruce
[Url] http://www.picbasic.co.uk/forum/showthread.php?t=12553 [/ url]
I have a database program that manages 16f628 keyboard matrix and I
want to pass on the Bruce to use the clock (RTCC) internal peak.
Thank you
C'est toujours clair comme de l'eau de boudin, ton truc ... :D
May we understand you want to add some internal RTCC feature to your 628 existing program AND , of course, change used processor to a RTCC equipped one ???
Everything depends on what YOUR program does and how it does it ... the RTCC is just something like a memory you write to and read from when needed ... soooo...
Perfectly possible ... @ first sight.
