assembler errors
hi,m learning pic basic pro programming and i developed code which will turn on 8 LEDs which are connected to PORTB of a PIC microcontroller.When the project is started (or when reset), the LEDs scroll to the right with a 250ms delay between each output. The sample code developed is as follows
j var byte 'define variable jam as byte type
trisb=0 'set port direction
mwanzo: 'start of the loop
j=128 'initialize counter
while j<1
PORTB=j 'send the counter value to the port
pause 250 'delay for 250ms
j=j>>1 'shift right once
wend
goto mwanzo 'repeat once again
when i compiled the program on MCS IDE i with pic16f877 selected i get the following errors:
Error LED_SC~1.ASM 48:[255] undifined symbol 'chk?rp'
Error LED_SC~1.ASM 48:[255] undifined symbol 'move?cb'
Error LED_SC~1.ASM 52:[231] attempt to redifine 'label?l'
Error LED_SC~1.ASM 51:[255] undifined symbol 'chk?rp'
Error LED_SC~1.ASM 51:[255] undifined symbol 'move?cb'
Error LED_SC~1.ASM 53:[255] undifined symbol 'cpmge?bcl'
Fatal LED_SC~1.ASM 53:[300] to many errors
when i change the pic selection to 16f628 the program run successful!!but development board im using have pic16f877 and i got the same type of errors in other programs i developed although some other program compiled secessfully. I need help on this
Re: assembler errors
Those are the standard Library macro's.
Have you edited your 16F877.bas file for any reason?
Were there any other errors BEFORE those?
Make sure your c:\pbp\16f877.bas file looks like this ...
'* 16F877.BAS *
'* By : Leonard Zerman, Jeff Schmoyer *
'* Notice : Copyright (c) 1998 microEngineering Labs, Inc. *
'* All Rights Reserved *
'* Date : 10/23/98 *
'* Version : 2.11 *
'* Notes : *
BANK0 $0020, $007F
BANK1 $00A0, $00EF
BANK2 $0110, $016F
BANK3 $0190, $01EF
EEPROM $2100, $21FF
LIBRARY "PBPPIC14"
DEFINE CODE_SIZE 8
include "PIC14EXT.BAS"
PORTL VAR PORTB
PORTH VAR PORTC
TRISL VAR TRISB
TRISH VAR TRISC
include "PBPPIC14.RAM"
'*-----------------------* EOF 16F877.BAS *---------------------*
And your program won't work, because j will never be less than 1 and the WHILE won't execute.
Thanx Darren, I've not changed the 16f877.bas file and i had only syntax error before the assembler errors occurred. The 16f877.bas looks the same as yours.i have changed the loop but still the same errors occur. the code is
j var byte 'define variable j as byte type
trisb=0 'set portb direction
mwanzo: 'start of the main program
again: 'start of the loop
if j=1 then mwanzo
goto again 'repeat once again
i wonder why the same errors still persist...i need more help on this
Could you email the .LST file after a failed compile?
[email protected]
