Please Help How Simplifies my code
HI EVERYONE
CODE IS WORKING BUT.
I AM CONFUSED THAT CODE TAKE LONG SPACE FOR SIMPLIFI WHAT IS AN OTHER WAY?
MY CODE IS
@ DEVICE PIC16F688, HS_OSC, WDT_OFF, PWRT_OFF, MCLR_OFF, BOD_OFF,PROTECT_OFF
DEFINE HSER_SPBRG 9 ' 115200 Baud @ 18.432MHz, 0.0%
TRISA =%11111111
TRISC =%11110111
ANSEL = 0 'ALL DIGITAL
INTCON = 0 'Disable interrupts
DATAIN VAR byte[7]
X VAR BYTE
LED VAR PORTC.3
MAIN:
HSERIN [WAIT($07,$06), str DATAIN\7]
GOSUB A
GOSUB B
GOSUB C
GOSUB CK
GOTO MAIN
A:
IF DATAIN[2]=$2D AND DATAIN[3]=$A1 AND DATAIN[4]=$00 AND DATAIN[5]=$CD AND DATAIN[6]=$C2 THEN
X[0]=1
X[0]=0
B:
IF DATAIN[2]=$2B AND DATAIN[3]=$FA AND DATAIN[4]=$3B AND DATAIN[5]=$65 AND DATAIN[6]=$0C THEN
X[1]=1
X[1]=0
C:
IF DATAIN[2]=$2E AND DATAIN[3]=$69 AND DATAIN[4]=$06 AND DATAIN[5]=$A6 AND DATAIN[6]=$21 THEN
X[2]=1
X[2]=0
CK:
IF X[0]=0 AND X[1]=0 AND X[2]=0 THEN
LOW LED
HIGH LED
GOTO MAIN
Re: Please Help How Simplifies my code
Try splitting up the long logical expressions, like:
A:
IF DATAIN[2]=$2D THEN
IF DATAIN[3]=$A1 THEN
IF DATAIN[4]=$00 THEN
IF DATAIN[5]=$CD THEN
IF DATAIN[6]=$C2 THEN
X[0]=1
X[0]=0
MANY THANKS MY BROTHER HenrikOlsson FOR REPLY
WHAT YOU THINK ABOUT
SELECT CASE
HOW CAN I USE ?
You're welcome, but there's no need to SHOUT all the time ;-)
SELECT CASE might give you "neater" code but I've found it usually produces larger code than IF-THEN constructs and in this particular case I don't think Select Case is of any use to you.
Another thing that might be worth a try is to do the extract the values from the array into temporary variables first, then run your comparisons. Something like:
TempA = DataIn[2]
TempB = DataIn[3]
TempC = DataIn[4]
TempD = DataIn[5]
TempC = DataIn[6]
GOSUB A
GOSUB B
'And so on
A:
If TempA = xx THEN
If TempB = xx THEN
'and so on
I'm sure there are more you can do depending on exactly what it is you're trying to achieve.
Are you sure this is not the reason for the slow code?
After all, no matter how you code the checks, the pic will not take a noticable time to process that. If it compiled to 1000 lines of code, @4Mhz clock it would only take 1mSec
What clock speed?
HenrikOlsson
A:
X[0]=1
X[0]=0
ABOVE CODE IS NOT WORKING
THIS IS A GOOD FORUM FOR BEGINNAR LIKE ME AND I HOPE HELP SO,
MY PROBLEM IS NOT slow code CLOCK IS 18.432MHz
100,S STRING I WANT COMPARE
Of course it doesn't, sorry about that. Try this instead:
A:
X[0]=0
X[0]=1
And please stop SHOUTING all the time, it's hard to read!
