Pic18f24j50 usb>>rtc
I am using a PIC18F24J50 that has a internal RTC, I need to be able to set the time from a VB program over USB, I can get the data from the VB program to the PIC, I just need to to know how to set the clock once I get the data. I will send something like this:
Time: 06:59:23
Date: 02:08:2011
Bob
Re: Pic18f24j50 usb>>rtc
Have you checked Chapter 16 of the device data sheet?
Yes, I looked at section 16.2.2.1 and it states if I want to use the internal Oscillator by setting CONFIG3L<1>, I just can't find anyone who knows where you set that. Any idea?
You set the fuses in the PBP *.inc file or in code space.
To find all of the options go to the MPASM Suite
C:\Program Files\Microchip\MPASM Suite
And find the *.inc file for your chip there, do not modify this file.
Read the post, looked in the 18F24J50.inc file and still not seeing anything that references settiing
CONFIG3L<1>
PBP include files do NOT include every single config option. They're normally only going to include just enough to help you get the PIC up & running.
It's up to you to read the data sheet, and config options you want to change if the default header file doesn't configure everything you want to change from the default.
For a complete list of all config options, don't look in the PBP .INC file. Look in the P18F24J50.INC file in your MPASM Suite directory. This has a list of every single config option the PIC type has, and explains what each option does.
In the microchip include file for this PIC type you'll see;
; RTCC Clock Select:
; RTCOSC = INTOSCREF RTCC uses INTRC
; RTCOSC = T1OSCREF RTCC uses T1OSC/T1CKI
Now look in the PIC data sheet config section for what each of these options are. I do not recommend you use the internal osc for RTC if you want a precise clock.
