Hello,
I have an application where the user pushes a press button to start the menu and also uses the same push button to scoll through the values. It should work fine if the button is press for under a second. But is there anyway to control the lenght of the pull down time? Lets says the user keep pressing on the button for 10 seconds, its will probable go through all the menus as fast as it can !! is there any way to prevent this ???
thanks
K
