Port bit manipulation useing variables
Hello,
I Am writing a Modbus RTU program to talk with an ILon 100 internet Server. I am trying to streamline my code. I am using modbus single coil write function to write the value of PortB single bit values. The program below works but is there a better way than Case Select. When I say better I mean less code and faster. This is not the whole code but is the jist of the Case Select.
WriteSingleCoil:
W0 = buffer[3]*255 + buffer[4] 'Combines MFrame 2 byte address into 1 word.
W0 = w0 - 10 'Sets up bit address for portB
If buffer[5] > 0 Then
Coilstate = 1
Coilstate = 0
Select Case W0
Case 1
PORTB.0 = Coilstate
Case 2
PORTB.1 = Coilstate
case 3
PORTB.2 = Coilstate
case 4
PORTB.3 = Coilstate
case 5
PORTB.4 = Coilstate
case 6
PORTB.5 = Coilstate
case 7
PORTB.6 = Coilstate
Case 8
PORTB.7 = Coilstate
Case else 'test to see if program is getting here
portb = 255
End Select
For B0 = 1 To 8 ' Send the response to Master
B1 = buffer[B0]
Gosub charout
Next B
Is there a way to do something like this.
PortB.w0 = Coilstate
I tryed this but it does not work. I'm going to try to use an aliass next but Im not sure if thats a good choice either.
Nick
