MPU-6000 World’s First Integrated 3-axis Gyroscope, 3-axis Accelerometer
I thought this was pretty cool. Gyros and accelerometers all in one chip, the first of its kind.
http://invensense.com/mems/gyro/mpu6000.html
- Digital-output of 6 or 9-axis sensor fusion data in rotation matrix, quaternion, or Euler Angle format
- Tri-Axis angular rate sensors (gyros) with a sensitivity of 131 LSBs/°/sec and a full-scale range of ±250, ±500, ±1000, and ±2000°/sec
- Tri-Axis accelerometers with a programmable full scale range of ±2g, ±4g, ±8g and ±16g
- Reduced settling effect and sensor drift by eliminating cross-axis sensitivity between accelerometers and gyros
- Digital Motion Processing™ (DMP™) engine offloads complex sensor fusion, sensor timing synchronization and gesture detection
- Motion Processing Library support for Android, Linux and Windows
- Embedded algorithms for run-time bias and compass calibration. No user intervention required
- Digital-output temperature sensor
- Digital input on Sync pin to support video Electronic Image Stabilization and GPS
- Programmable interrupt supports gesture recognition, panning, zooming, scrolling, free fall interrupt, high-G interrupt, zero-motion detection, tap detection, and shake detection
- VDD supply voltages of 2.5V±5%, 3.0V±5%, 3.3V±5%; VDDIO at 1.8V± 5%
- Gyro operating current: 5mA, gyro standby current: 5µA; accelerometer operation current: 350µA, accelerometer low power mode current: 20µA@10Hz
- 400kHz Fast Mode I2C or up to 20MHz SPI serial host interfaces
- On-chip timing generator with ±1% frequency variation over full temperature range
- User self test
- 10,000 g shock tolerant
- Smallest and thinnest package for portable devices (4x4x0.9mm QFN)
- RoHS and Green compliant
