windows7pro and microcode studio compatibility
so working for two days trying to get the MicroCode studio plus, PBP, and the U2 programmer to work and still no luck have set and unset admin and compatibility modes without sucess. I have 64bit win7pro on an hp dv6 laptop. I get constant errors when starting that the MCS it has stopped working and search for fix online but none to be found. in win7 though the U2 programmer is working.
Tried XP mode(Virtual Machine) and the mcs seems to work and PBP also but the MElabs U2 programmer is never found as recognizable because it is a hid device.
Any ideas would be greatly appreciated
further notes on failure in mcs+ PBPro
So in trying to isolate the fault in my software I found that when PBP is installed and selected in the compiler options is when I get the fault on startup. If I install the PBP demo from the X1 tutorial CD and point the complier to it all is fine. But the demo isn't what I want to use...
The ApplicationError that shows up is
Exception EInvalidPointer in module CodeStudioPlus.exe at 00018DC2
Invalid pointer operation
Do you think my CD can be bad?
