Math question relating to AD input on PIC12F675
Hello all,
This is my first PIC code in several years. Even back then, I only wrote a few simple programs and that will be obvious when you read my question. :)
I think that I'm OK with all the circuitry, and the main code isn't yet finished, but I would like for someone to help guide me with the math.
Let's assume that I have all the configurations correct.:rolleyes:
I'll have a pot connected to AN2, which is configured for 8 bits. This should give me a value of 1 - 255 at AN2. I want to convert that range of numbers (1 - 255) into seconds and then use the new value in a variable for the PAUSE command. The code, I believe, should give me a range of 1 - 63 seconds. I just don't know how the decimal places will be handled and if the PAUSE command accepts non-whole numbers.
Thanks and regards,
Mitch
delayloop:
ADCIN 2, adval ' read in value at AN2.
IF adval <4 THEN ' make lowest value to be 4 which would equate
adval = 4 ' to a 1 second pause.
delay = adval /4 * 1000 ' convert AD value of 1 - 255 into 1 - 63 second pause.
PAUSE delay ' pause from 1 - 63 seconds.
