im using a resanator, 20 mhz,
which option do i use
lp
xt
hs
rc
lp
xt
hs
rc
HS, if your crystal is higher than 4MHZ
do i need to
______
DEFINE osc 20
______
at the begining of my code,, i use microcode studio to compile, thenicprog to burn,
is there any other configuration lines i need,
when using a different crystal than 4MHZ you need to place this include line, AND set your crystal fuse into your programmer (HS,XT,LP...)
not much :)
