variable modifiers / aliases...
ok, first off... i'm now the proud owner of PBP2.60a... u2 programmer is also on it's way...
i'm driving a stepper motor driver IC from a pic.
the driver IC has several inputs for it's settings...
For example, torque setting is two bits (4 settings), 25%(00), 50%(01) 75%(10) and 100% (11).
PBP doesn't support doing the following...
Torque var byte
torque.0 var PORTD.6
Torque.1 var PORTD.5
The torque setting is changed from the menu (to be writen) so it would be easier to just increase the variable by 1 up to 4 rarther than having to mess around with torque1 and torque2 separate vars.
is their a better way?
