NiCD - Charging circuit - Using PIC
Hi, I have a winch machine which I have modified to work with the remote instead of the its wired control box. I was hoping if someone can help me develop a charging circuit with battery low indicator & full charge indication circuit with or without PIC for the remote. I have couple of 12F676 for the job if needed.
I have made 3 battery packs of four 1.2V (700mAH) NiCD each, so each pack has 4.8V & total current 2.1 AH for the transmitter. I have a spare nokia charger with 5.7V @ 800mA output which I am hoping to use for this purpose. So if anyone knows or have seen any circuit which puts all together, please share it.
Multiple Chemistry Battery Charger Solution Using MCP1631HV PIC Attach PWM Controller
Here is Microchips AN1293, but it requires a MCP1631HV chip. Might give you some ideas though.
http://www.microchip.com/stellent/id...pnote=en544929
Thanks to all + A new thought
I would like to thanks everyone who has contributed above. Finally, I will see if I can find MAX4080 easily where I am.
There is one new problem, I don't know if I should start a new thread or carry on here, but I will give it a shot here first: So here I go:
I have one Doorbell, it runs on mains 230V currently, few zeners drop the voltage after the rectifier and through 78L05 the PIC & the RF receiver get their 5 V.
Now I would like to modify this circuit in such a way, that if there is a power cut, the system should switch onto two AA standby batteries for brief period of times (like appx 1 hour or so every few days) . Both PIC & RF receiver can work on appx 3V minimum (PIC can go down upto 2.5V). Now, these batteries are not chargeable, so no voltage should enter in them, I had a eureka moment and thought that it can be done with diodes, but the voltage drop across them makes them unsuitable as I only have around 0.6 V (new AA have appx 3.6V) appx to play with and I can't share it with the diode. Can someone think of a suitable circuit that will make this a possibility(with easily available components)?
