Digital pot 257 steps - confused!
Well, after a bit of to-ing & fro-ing, I've managed to get my digital pot controlled via a PIC using SPI.
One puzzlement disappears (how to get SPI working), but another one surfaces ........... I bought a 257 position pot (an MCP44251 - http://ww1.microchip.com/downloads/e...Doc/22060b.pdf ) *But* check this out.
If I send this...
command = %00000000 (ie a write command)
r_value = %111111111 (ie 'a wiper value of 255' or just 2 away from the 257 step maximu value) I see this...
http://img409.imageshack.us/img409/9480/36257420.jpg
(green trace is the input to the pot, yellow trace is the wiper out)
In other words, the signal is nowhere near maximum?
If I send it this...
command = %00000001
r_value = %10000000
It gets a little bigger...
http://img175.imageshack.us/img175/5715/81977059.jpg
I *can* actually get the wiper output signal to maximum (ie output = to the input signal) by sending this to the pot...
command = %00000010
r_value = %00000000
So bearing in mind the data byte is 8 bits... it appears that this digipot also uses 2 bits from the command byte - that's 10 bits....so how come 257 steps?
What gives?!!
And also the fact that it uses 8 bits in a data (wiper value) byte...but also 2 bits from the command byte (least signifcant bits) ....that's got my head spinning how I approach controlling the pot in practise? (ie with the wiper control bits breaching byte boundaries) What's the std here?!!
