Stack Overflow - Stack Underflow
@ device INTRC_OSC_NOCLKOUT
@ device wdt_off
@ device pwrt_on
@ device protect_off
include "Tanimlar.inc"
Ana:
gosub Chk_KEYPAD
if say = 3 then
gosub kilit
pause 1
goto Ana
Chk_KEYPAD:
for row = 0 to 3
PORTB = (dcd row) ^ $f
pause 1
col = PORTB >> 4
if (col <> $f) then 'tuşa basıldı
key = (row * 3) + (ncd (col ^ $f))
low buz
pause 70
high buz
while (PORTB >> 4) <> $f
pause 1
wend
if key = 11 then key = 0
TusBuff[tussay] = key
if psw.0 = 0 then
gosub Chk_tussay
gosub chk_tussay2
key = 255
next
Beep:
high ld1
low buz
pause 70
high buz
pause 70
low buz
pause 70
low ld1
high buz
Chk_SfrOK:
psw.1 = 0
psw.2 = 0
psw.3 = 0
psw.4 = 0
psw.5 = 0
psw.6 = 0
if (TusBuff[0] = SfrBuff[0]) and (TusBuff[1] = SfrBuff[1]) and (TusBuff[2] = SfrBuff[2]) and (TusBuff[3] = SfrBuff[3]) then psw.1 = 1
if (TusBuff[0] = SfrBuff[4]) and (TusBuff[1] = SfrBuff[5]) and (TusBuff[2] = SfrBuff[6]) and (TusBuff[3] = SfrBuff[7]) then psw.2 = 1
if (TusBuff[0] = SfrBuff[8]) and (TusBuff[1] = SfrBuff[9]) and (TusBuff[2] = SfrBuff[10]) and (TusBuff[3] = SfrBuff[11]) then psw.3 = 1
if (TusBuff[0] = SfrBuff[12]) and (TusBuff[1] = SfrBuff[13]) and (TusBuff[2] = SfrBuff[14]) and (TusBuff[3] = SfrBuff[15]) then psw.4 = 1
if (TusBuff[0] = SfrBuff[16]) and (TusBuff[1] = SfrBuff[17]) and (TusBuff[2] = SfrBuff[18]) and (TusBuff[3] = SfrBuff[19]) then psw.5 = 1
if (TusBuff[0] = MKSfrBuff[0]) and (TusBuff[1] = MKSfrBuff[1]) and (TusBuff[2] = MKSfrBuff[2]) and (TusBuff[3] = MKSfrBuff[3]) then psw.6 = 1
if psw.1 = 0 and psw.2 = 0 and psw.3 = 0 and psw.4 = 0 and psw.5 = 0 and psw.6 = 0 then
if TusBuff[tussay] = 12 or TusBuff[tussay] = 10 then
if psw.6 = 0 then
gosub Hata
Chk_NewSfrOK:
psw.1 = 0
psw.2 = 0
psw.3 = 0
psw.4 = 0
psw.5 = 0
psw.6 = 0
if (TusBuff[5] = TusBuff[10]) and (TusBuff[6] = TusBuff[11]) and (TusBuff[7] = TusBuff[12]) and (TusBuff[8] = TusBuff[13]) then
psw.1 = 1
psw.6 = 1
Sifre_Degis:
if psw.1 then
SfrBuff[0] = TusBuff[5]
SfrBuff[1] = TusBuff[6]
SfrBuff[2] = TusBuff[7]
SfrBuff[3] = TusBuff[8]
if psw.2 then
SfrBuff[4] = TusBuff[5]
SfrBuff[5] = TusBuff[6]
SfrBuff[6] = TusBuff[7]
SfrBuff[7] = TusBuff[8]
if psw.3 then
SfrBuff[8] = TusBuff[5]
SfrBuff[9] = TusBuff[6]
SfrBuff[10] = TusBuff[7]
SfrBuff[11] = TusBuff[8]
if psw.4 then
SfrBuff[12] = TusBuff[5]
SfrBuff[13] = TusBuff[6]
SfrBuff[14] = TusBuff[7]
SfrBuff[15] = TusBuff[8]
if psw.5 then
SfrBuff[16] = TusBuff[5]
SfrBuff[17] = TusBuff[6]
SfrBuff[18] = TusBuff[7]
SfrBuff[19] = TusBuff[8]
Write 0, SfrBuff[0] 'Yeni şifre EEprom'un 0..3 adreslerine kaydedildi
Write 1, SfrBuff[1]
Write 2, SfrBuff[2]
Write 3, SfrBuff[3]
Write 4, SfrBuff[4] 'Yeni şifre EEprom'un 0..3 adreslerine kaydedildi
Write 5, SfrBuff[5]
Write 6, SfrBuff[6]
Write 7, SfrBuff[7]
Write 8, SfrBuff[8] 'Yeni şifre EEprom'un 0..3 adreslerine kaydedildi
Write 9, SfrBuff[9]
Write 10, SfrBuff[10]
Write 11, SfrBuff[11]
Write 12, SfrBuff[12] 'Yeni şifre EEprom'un 0..3 adreslerine kaydedildi
Write 13, SfrBuff[13]
Write 14, SfrBuff[14]
Write 15, SfrBuff[15]
Write 16, SfrBuff[16] 'Yeni şifre EEprom'un 0..3 adreslerine kaydedildi
Write 17, SfrBuff[17]
Write 18, SfrBuff[18]
Write 19, SfrBuff[19]
Chk_tussay:
select case tussay
case 4
gosub Chk_SfrOK
if psw.1 or psw.2 or psw.3 or psw.4 or psw.5 or psw.6 then
if TusBuff[tussay] = 12 then Kilit_acik
if TusBuff[tussay] <> 10 then Clr_TusBuff
gosub Beep
gosub Clr_TusBuff
case 9
if TusBuff[tussay] <> 12 then Clr_TusBuff
gosub Beep
case 14
if psw.6 = 0 then
gosub Beep
gosub Chk_NewSfrOK
if psw.1 or psw.6 then
gosub Beep
gosub Sifre_Degis
gosub Beep
gosub Clr_TusBuff
gosub Clr_TusBuff
case 16
if TusBuff[tussay] <> 12 then clr_TusBuff
gosub beep
gosub Chk_NewSfrOK
if psw.6 then
gosub Beep
gosub Sifre_Degis
gosub Beep
gosub Clr_TusBuff
gosub Clr_TusBuff
case else
if TusBuff[tussay] = 12 then Clr_TusBuff
end select
tussay = tussay + 1
Chk_tussay2:
select case tussay
case 4
if psw.6 then
psw.0 = 0
gosub Beep
gosub Clr_TusBuff
case 9
gosub Beep
case 14
gosub Beep
gosub Chk_NewSfrOK
if psw.6 then
gosub Beep
gosub Sifre_Degis
psw.0 = 0
gosub Beep
gosub Clr_TusBuff
gosub Clr_TusBuff
case else
end select
tussay = tussay + 1
Reset:
for cnt = 0 to 14
TusBuff[cnt] = cnt
next
low ld1
high buz
tussay = 0
psw.0 = 0
psw.1 = 0
psw.6 = 0
say = 0
Hata:
say = say + 1
high ld1
low buz
pause 200
low ld1
high buz
Kilit_acik:
if psw.0 = 0 then
say = 0
high mtr ' motoru çalıştır
High frw ' İleri dön
pause Frw_time ' ileri dönme süresi
low frw
low mtr
pause wait_time ' bekleme süresi
high BCK ' geriye dön
pause bck_time ' geriye dönme süresi
low BCK
low mtr
gosub Reset
Clr_TusBuff:
for cnt = 0 to 14
TusBuff[cnt] = cnt
next
tussay = 0
gosub Ana
Kilit :
psw.0 = 1
low buz
high ld1
gosub chk_KEYPAD
gosub Kilit
when simulating in proteus, errors occur:
Stack overflow executing CALL instruction;
the device is PIC16F628A
What's wrong?
