Simple PIC based timer needed, any advice appreciated.
Im new to this forum so hello everyone! Sorry if this is posted in the wrong place.
I need a simple timer that will pulse for 2 seconds once in every (approx) 24 hours. Physical size must be small as it is to be fitted into existing equipment. Hence why I thought of a PIC solution. 5 volts available and it would need to trigger a miniture relay. Permanently connected to power so would need to reset and then wait a further 24 hours and send a pin high for 2 seconds again.
I know its a simple request but Ive had no luck in finding anything on the web, so if anyone could point me in the right direction that would be very much appreciated!
Chris
Re: Simple PIC based timer needed, any advice appreciated.
Hi All,Very new to Pic Programming and very new to your forum. I found this thread searching Google for ideas on progrmming a PIC on a 24hour cycle. Ok the problem, I have a JDM programmer and when I try to write to a 10F200 PIC all I get is, [IMG]file:///C:/DOCUME~1/BENSHE~1/LOCALS~1/Temp/msoclip1/01/clip_image001.png[/IMG]I have tried running it from the ZIF sockets and the off board connectors????Am stuck now??? Any ideasCheersDagwood
Moved from Schematics.
