Store and retrieve strings to an ATmel SPI Serial EEprom
I have normally worked with other compilers but at work I have to use Picbasic Pro. Usually I use a Pascal language compiler. Anyways, I am finding it kind of difficult to do something simple like store strings in an external serial eeprom for call back later. I will have many strings of varing lengths possible over 100 of them. I am using a 16 meg atmel double buffered serial (SPI) eeprom. I can write data (decimal numbers) to the eeprom and read it back. But what to do about strings? I don't have too much experience with PBP yet but learning fast. I know I don't have the option of having a string variable :confused:. So, my guess is load each character into an array and send it out one at a time. Once the strings are loaded into the eeprom I can comment out or delete the code that put them there. The rest of the memory will be used for storing A/D data. I guess the big question is when I load the strings back into the PIC can I convert them to ascii again for output to an LCD.
Anyone have any samples of how I can do something like this? I don't need someone to write all the code for me as I'm a big boy now. I just need to see a way to create an array of characters, do a shiftout of each character and then do a shiftin and reassemble the string for an LCDout. I've already tried to do this but just got some garbage on the LCD.
For the Mel guys, Yes, a string var would be nice and some simple string handling functions like other compilers have ie.... mikroe.
Bryan
