H Again everyone;
I made a program for 3 pic's with 3 SN75176, and they are connected in RS485 bus. The interrupts are working fine, however, it seems that the Main loop frezzes, but if enable a interrupt, serial ou external, the interrupt is executed, but the main loop frezzes again.
Hee is the code;
Can somebody take a look at my code, and see where is he mistake.Code:'*********************************************************************
'* Name : RS485 + Interrupt.BAS *
'* Author : Hugo Oliveira *
'* Notice : Copyright (c) 2010 ProSystems *
'* : All Rights Reserved *
'* Date : 10-08-2010 *
'* Version : 1.0 *
'* Notes : *
' INCLUDE's e FUSES
@ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _BODEN_OFF & _LVP_OFF & _CP_OFF & _DATA_CP_OFF
include "modedefs.bas"
INCLUDE "DT_INTS-14.bas"
' CONFIGURAÇÃO DAS INTERRUPÇÕES
INT_Handler RX_INT, _IntRx, ASM, yes
INT_Handler INT_INT, _IntBt, ASM, yes
INT_CREATE
@ INT_ENABLE RX_INT
@ INT_ENABLE INT_INT
' VARIÁVEIS
DADOS var byte[4]
ID var byte
I VAR BYTE
wsave VAR BYTE $70 SYSTEM
' REGISTOS PINOUT 1 = IN; 0 = OUT
'76543210
TRISA = %00000000
TRISB = %00000011
CMCON = 7
VRCON = 0
' NOMES PINOUT
LED VAR PORTA.2
LED1 VAR PORTA.1
Botao var PORTB.0
TX Var PORTB.2
RX VAR PORTB.1
COM VAR PORTB.3 'SN75176 ENABLE TRANSMITE
' DEFINIÇÕES
DEFINE HSER_RCSTA 90h
DEFINE HSER_TXSTA 20h 'Testado 300-20h,600-20h,1200-20h,2400-20h,4800-24h,9600-24h,14400-24h,19200-24h,28800-24h
DEFINE HSER_BAUD 1200
DEFINE HSER_CLROERR 1
' INICIO PROGRAMA
LOW COM 'DEACTIVATE SN75176
high led
for i = 1 to 200
pause 1
next
low led
for i = 1 to 200
pause 1
next
Goto Main
' ROTINA INTERRUPÇÃO SÉRIE
IntRx:
Hserin 20,RXfail,[wait("OK"),DEC2 ID, str DAdos\4]
if ID = 01 then
ARRAYREAD DAdos, 4,No_Hugo,[WAIT("Hugo")]
high led1
No_Hugo:
ARRAYREAD DAdos, 4,RXfail,[WAIT("LOWL")]
low led1
RXfail:
@ INT_RETURN
' ROTINA INTERRUPÇÃO POR BOTÃO
IntBt:
HIGH COM 'ENABLE SN75176
hserout ["OK00Hugo"]
@ INT_RETURN
The code is equal do the 3 PICS, except the ID of each one and the HSerout string.
Thanks in advance.
