Can someone please
1) Explain the calculation behind MAXDELAY in the following program
2) Confirm if in Dimmers only Positive half is controlled (and WHY)?
Code:' Lamp dimmer
' File name : LampDim.bas
' Company : Mister E
' Programmer : Steve Monfette
' Date : 23-12-2004
' Device : PIC12F675
' This program is use to dim intensity of an AC line load
' like lamp, motor and other. Developped for 60 Hz line.
' This allow to increase or decrease intensity.
' If the user doesn't held at least 0.5 sec:
' 1. "Increase" : we will set the output for full brightness
' 2. "Decrease" : we will turn off the output
' The software need :
' 1. A full wave signal from the AC line on GP4
' The software use :
' 1. TIMER1 overflow to check if pushbutton are hold for
' more than 0.5 Sec
' 2. Interrupt on GP4 (AcLine input) to synchronise Triac
' Device programming mode and hardware definition
' Using Internal Clock, no clock out
' Enable Watch dog timer
' Disable MCLR pin
' Enable Power-up timer
' Enable Brown-out detect
@ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _PWRTE_ON & _BODEN_ON
TRISIO = %11111011
OPTION_REG.7=0 ' Enable pull-ups
WPU=%00000011 ' Enable pull-ups on GP0, GP1
CMCON=7 ' Disable analog comparator
ANSEL=0 ' Disable analog converter
Pb_Inc var GPIO.0 ' Input for INCREMENT/ON push button
Pb_Dec var GPIO.1 ' Input for DECREMENT/OFF push button
Triac var GPIO.2 ' Output to TRIAC gate
ACLine var GPIO.4 ' Input for the FullWave rectify AC line
' Software definition
MaxDelay var word
TriacDelay var Word
Debounce_AutoRepeatDelay var word
FullBright var bit
' Interrupts definition
INTCON=%10001000 ' Enable interrupt on GPIO change
IOCB.4=1 ' Enable interrupt on GP4 change
PIE1.0=0 ' disable TMR1 overflow interrupt
T1CON=%00110100 ' Set TIMER1
' prescaler 1:8
' internal clock (Fosc/4) 1MHZ
' synchro internal
' we will use TIMER1 overflow
' $ffff * 8* (1/(4MHZ / 4)) = 0.524 Sec
ON INTERRUPT GOTO ACDetect
' Hardware and variable initialisation
Maxdelay=6000 ' Set Maximum delay (set to 8000 for 50Hz)
FullBright=0 ' disable Full Brightness flag
triac=0 ' disable Triac Gate
triacdelay=0 ' Set delay to minimum
gosub ResetTimer1 ' reset Timer1
' Main
' Get entry from user to Increment of Decrement intensity
start:
' Test Increment push button
' If hold more than .5 Sec, increment triac gate delay by 500 uSec
' case else Full brightness at output
while Pb_inc=0
gosub TestTimer1 ' test status of TIMER1
while (Pb_inc==0) AND (PIR1.0==0) 'loop while holding push button
'and no TIMER1 overflow
wend
if PIR1.0==1 then ' If timer overflow (pushbutton hold for > 0.5 sec),
T1CON.0=0 ' disable TMR1
gosub Debounce_AutoRepeat
if (triacdelay<Maxdelay) then
triacdelay=triacdelay+500 'increment Triac gate delay
triacdelay=maxdelay ' if triacDelay>MaxDelay,
fullbright=1 ' set the full brightness Flag
triacdelay=maxdelay ' If pushButton was hold less than .5 sec
Fullbright=1 ' Set the full brightness flag
wend
gosub ResetTimer1
' Test Decrement push button
' Case else, turn off output
while Pb_dec=0
gosub TestTimer1 ' Test status of TIMER1
while (Pb_dec==0) AND (PIR1.0==0) 'loop while holding push button
wend
T1CON.0=0 ' disable TIMER1
if (triacdelay>0) then
Fullbright=0 ' Reset TRIAC always ON flag
triacdelay=triacdelay-500
triacdelay=0
wend
gosub ResetTimer1
goto start
' TestTimer1
' Enable TIMER1 if :
' not enable and not in overflow
TestTimer1:
if (T1CON.0==0) AND (PIR1.0==0) then 'if TIMER1 not enable
'and TIMER1 not overflow
T1CON.0=1 'enable TIMER1
' ResetTimer1
' Subroutine to clear Timer1
' 1. Overflow flag
' 2. Disable Timer
' 3. Clear counter
ResetTimer1:
PIR1.0=0 'clear timer overflow
T1CON.0=0 'disable timer
TMR1L=$00 'clear counter
TMR1H=$00 '
' Debounce_AutoRepeat
' Subroutine to debounce push button.
' Also provide kind of auto-repeat when push button
' are held down.
' each delay = 20 mSec
' Use of PAUSEUS to be sure getting ACLine interrupt
Debounce_AutoRepeat:
for Debounce_AutoRepeatDelay=1 to 2000
pauseus 10
next
' ACDetect
' Interrupt routine called by ACLine (GP4) pin state change
disable
ACDetect:
if ACline==1 then ' Check for rising edge of AC signal
if triacdelay > 0 then
Triac=1 ' Activate TRIAC
if FullBright==0 then ' In case Brightness flag is not set
pauseus triacdelay ' do the selected delay
triac=0 ' Disable TRIAC
triac=0
INTCON.0=0 ' Clear GPIF (interrupt on GP4 change)
resume
enable
