Darrel Taylor's SPWM code usage
		Hello All
   A while ago I tried using Darrel Taylor's "Instant Interrupts. The demo showed that
three separate items could run (seemingly) at the same time using this interrupt scheme. It is a great piece of code.
Recently I tried to use the SPWM code with a 16F628a and three LEDs. After a day of
 "it won't run at 20MHZ problems", I finally found the problem in posts concerning "setting fuses". If you are
venturing from 4MHZ to 20 MHZ for the first time, take the time to read these posts. Fuses are a real "gotcha" and
this may save you hours of frustration.
http://www.picbasic.co.uk/forum/show...ighlight=fuses
http://melabs.com/support/config_defaults.htm
	 Anyway...I finally got the SPWM demo to run. The problem I have is
that the only advantage I can find here is that the PWM function can be held at a certain value
after leaving a for next loop. That's good!  I could not do that with the basic PWM function
since the pulse generation stops when the loop is ended.
What I don't see in the demo is an example of the (magic) seemingly simultaneous interrupt scheme put to use as in
the "Instant Interrupts" code. I would like to run three PWM outputs independently controlled
using a technique similar to the one shown below. The SPWM demo uses a nesting of "for next" statements
but never seems to use the interrupt handlers. I have played around with INT settings in the
belly of the ASM beast but I'm just guessing.
Is this possible?  Am I making this clear, or should I have another beer?
Something like below except for SWPM......
   IF SecondsChanged = 1 THEN
      SecondsChanged = 0
      LCDOUT $FE,$C0, DEC Days,"d-",DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds
GOTO Main
ToggleLED1:
    TOGGLE LED1
@ INT_RETURN
'---[TMR0 - interrupt handler]-------------------------------(Blinky Light)------
T0Count  VAR WORD
ToggleLED2:
   T0Count = T0Count + 1
   IF T0Count = 512 THEN T0Count = 0 : TOGGLE LED2
@ INT_RETURN
"LISA,  JUST ANSWER THE QUESTION, DADDY SHOULD BET ON!......"
Thanks in advance.
