Power-on reset. Start-up timer.
Hello.
I have a pic16f690 in a project. It works fine at the developement board. But mounted at the card i like to use it with, the program will not start. (It starts if I push the MCLR-pin) Probably this problem is caused by a slow power-up, i have a condensator connected to pwr.
I read in the data cheet that this pic have a couple of featuers who maybee can solve my problem. Power-on-reset, power-up-timer and maybee others. But how do I program it into the pic??
I found this string in this forum: "_PWRT_ON_2L" but I can not find any other code ty try. (It didnīt help).
Can anyone help me?
/ Lasse
Supervisor chip unlikely to compensate for slow rise PSU
PIC18F4620 parameter D004 says 0.05V/mSec is the minimum dV/dT to get a reliable startup. A few years ago I had a dodgy system (with a Motorola xxxx supervisor chip) that was intermittent until I reduced the inlet filter capacitors to ensure faster voltage rise at power up.
Your mileage may vary but adding the supervisor did nothing for me.
HTH
BrianT
