I started to use a new MCU today 18F46J11 and of course I expect new problems. But I did not expect the DEFINE OSC 4 standard line to kill me. It did! I can not compile with any OSC setting IF I also set the configuration bits in the code. I do not understand why this does not work. I am on MPLAB v8.50 using PBP2.60a (yes I patched yesterday)
This works except I do not the config settings right
This does not workCode:ASM
CONFIG WDTEN = OFF ; Watchdog Disabled - Controlled by SWDTEN bit
CONFIG STVREN = OFF ; Stack Overflow/Underflow Reset Disabled
CONFIG XINST = OFF ; Extended Instruction Set Disabled
CONFIG CP0 = ON ; Program memory is code-protected
; CONFIG OSC = INTOSCPLL ; Oscillator INTOSCPLL
CONFIG T1DIG = OFF ; Secondary Oscillator clock source may not be selected T1OSCEN Enforcement
CONFIG LPT1OSC = ON ; Low-power operation Low-Power Timer1 Oscillator
CONFIG FCMEN = OFF ; Disabled Fail-Safe Clock Monitor
CONFIG IESO = OFF ; Disabled Internal External Oscillator Switch Over Mode
CONFIG WDTPS = 1 ; 1:1 Watchdog Postscaler
CONFIG DSWDTOSC = T1OSCREF ; DSWDT uses T1OSC/T1CKIDSWDT Clock Select
CONFIG RTCOSC = INTOSCREF ; RTCC uses INTRCRTCC Clock Select
CONFIG DSBOREN = OFF ; DisabledDeep Sleep BOR
CONFIG DSWDTEN = OFF ; DisabledDeep Sleep Watchdog Timer
CONFIG DSWDTPS = 2 ; 1:2 (2.1 ms) Deep Sleep Watchdog Postscaler
CONFIG IOL1WAY = OFF ; The IOLOCK bit (PPSCON<0>) can be set and cleared as needed IOLOCK One-Way Set Enable bit
CONFIG MSSP7B_EN = MSK5 ; 5 Bit address masking modeMSSP address masking
CONFIG WPFP = PAGE_0 ; Write Protect Program Flash Page 0Write/Erase Protect Page Start/End Location
CONFIG WPEND = PAGE_WPFP ; Pages WPFP<5:0> to (Configuration Words page) write/erase protected Write/Erase Protect Region Select bit (valid when WPDIS = 0)
CONFIG WPCFG = ON ; Configuration Words page erase/write-protected Write/Erase Protect Configuration Region
CONFIG WPDIS = OFF ; WPFP[5:0], WPEND, and WPCFG bits ignoredWrite Protect Disable bit
OSCCON=%11101000
OSCTUNE.6=1
Code:ASM
OSCCON=%11101000
OSCTUNE.6=1
