help with PIC16F628 conditional program
i'm having problem working with a conditional program,
@ DEVICE PIC16F628A, INTRC_OSC_NOCLKOUT, WDT_OFF, PWRT_OFF, MCLR_OFF,PROTECT_ON,CPD_ON, BOD_OFF, LVP_OFF
CMCON = 7
VRCON = 0
TRISA = 95
TRISB = 0
PORTB = 0
GS1 var PORTA.0
GS2 var PORTA.1
TEMP var PORTA.2
FWD VAR PORTA.3
REvs VAR PORTA.4
Neut var PORTA.7
forward var PORTB.0
revers var PORTB.1
one var PORTB.2
two var PORTB.3
three var PORTB.4
starterd var PORTB.5
start: IF Neut = 1 then
low forward
low revers
if (FWD = 1) and (REvs = 0) then
low revers
high forward
low revers
low forward
if (FWD = 0) AND (REvs = 1) then
low forward
high revers
goto start
i need to monitor all the possible conditions in my input then ouput the right combination following this table.
------ INPUTS-------|-----OUTPUTS-----
FWD---Neut--REvs-|---forward---revers
--0-------0------1---|------0-----------1
--1-------0------0---|------1-----------0
--0-------1------0---|------0-----------0
--0-------1------1---|------0-----------0
--1-------1------0---|------0-----------0
also i have problem on making PORTA.7 work as an input
i plan to add more functions when this part worked
TIA.
