18f452 interrupt problem
HI,
i'm trying to generate two oposite 16HZ square wave with a 18f452 but i'm lost
here is the code i am trying to use:
' | 18F452 |
' MCLR/Vpp ------> |1 40| <-----> RB7/PGD
' RA0/AN0 <-----> |2 39| <-----> RB6/PGC
' RA1/AN1 <-----> |3 38| <-----> RB5/PGM
' RA2/AN2/Vref- <-----> |4 37| <-----> RB4
' RA3/AN3/Vref+ <-----> |5 36| <-----> RB3/CCP2*
' RA4/TOCK1 <-----> |6 35| <-----> RB2/INT2
' RA5/AN5/SS/LVDIN <-----> |7 34| <-----> RB1/INT1
' RE0/RD/AN5 <-----> |8 33| <-----> RB0/INT0
' RE1/WR/AN6 <-----> |9 32| <----- Vdd
' RE2/CS/AN7 <-----> |10 31| <----- Vss
' Vdd -----> |11 30| <-----> RD7/PSP7
' VSS -----> |12 29| <-----> RD6/PSP6
' OSC1/CLK1 -----> |13 28| <-----> RD5/PSP5
' OSC2/CLKO/RA6 <------ |14 27| <-----> RD4/PSP4
' RC0/T1OSO/TICK1 <-----> |15 26| <-----> RC7/RX/DT
' RC1/T1OSI/CCP2* <-----> |16 25| <-----> RC6/TX/CK
' RC2/CPP1 <-----> |17 24| <-----> RC5/SDO
' RC3/SCK/SCL <-----> |18 23| <-----> RC4/SD1/SDA
' RD0/PSP0 <-----> |19 22| <-----> RD3/PSP3
' RD1/PSP1 <-----> |20 21| <-----> RD2/PSP2
'-- Clear All The Variables And Each Port Before Setting The TRIS Registers ---'
Clear 'Set all ram registers to zero
PORTA = 0
PORTB = 0
PORTC = 0
PORTD = 0
PORTE = 0
'--------------------------- VSS VDD MCLR Ect. Pins ---------------------------'
'MCLR (Pin 1)
'VDD (Pin 11)
'VSS (Pin 12)
'OSC/CLKIN (Pin 13)
'OSC2/CLKOUT (Pin 14)
'VSS (Pin 31)
'Vdd (Pin 32)
'((OPTION_REG=127 ' ENABLE WEAK PULL UP RESISTORS ON PORTB))
'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'
'XXXXXXXXXXXXXXXXXXXXXXXXXX Set The TRIS In/Out Pins XXXXXXXXXXXXXXXXXXXXXXXXXX'
'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX BELOW XXX'
'-------------------- PORTA PINS --------------------'
TRISA.0 = 1 '(pin 2) IN_LTC1966
TRISA.1 = 1 '(pin 3) NOT USED
TRISA.2 = 1 '(pin 4) NOT USED
TRISA.3 = 1 '(pin 5) NOT USED
TRISA.4 = 1 '(pin 6) NOT USED
TRISA.5 = 1 '(pin 7) NOT USED
'-------------------- PORTB PINS --------------------'
TRISB.0 = 0 '(pin 33) LED_10MN
TRISB.1 = 1 '(pin 34) BP_10MN
TRISB.2 = 0 '(pin 35) LED_5MN
TRISB.3 = 1 '(pin 36) BP_5MN
TRISB.4 = 0 '(pin 37) LED_3MN
TRISB.5 = 1 '(pin 38) BP_3MN
TRISB.6 = 1 '(pin 39) BP_STOP
TRISB.7 = 1 '(pin 40) BP_TEST
'-------------------- PORTC PINS --------------------'
TRISC.0 = 0 '(pin 15) LED8
TRISC.1 = 0 '(pin 16) LED9
TRISC.2 = 0 '(pin 17) LED10
TRISC.3 = 0 '(pin 18) LED11
TRISC.4 = 0 '(pin 23) LED12
TRISC.5 = 0 '(pin 24) LED13
TRISC.6 = 0 '(pin 25) LED14
TRISC.7 = 0 '(pin 26) LED15
'-------------------- PORTD PINS --------------------'
TRISD.0 = 0 '(pin 19) LED0
TRISD.1 = 0 '(pin 20) LED1
TRISD.2 = 0 '(pin 21) LED2
TRISD.3 = 0 '(pin 22) LED3
TRISD.4 = 0 '(pin 27) LED4
TRISD.5 = 0 '(pin 28) LED5
TRISD.6 = 0 '(pin 29) LED6
TRISD.7 = 0 '(pin 30) LED7
'-------------------- PORTE PINS --------------------'
TRISE.0 = 0 '(pin 8) SORTIE1
TRISE.1 = 0 '(pin 9) SORTIE2
TRISE.2 = 1 '(pin 10) NOT USED
;@ __CONFIG _CONFIG1H, _OSCS_ON_1H & _XT_OSC_1H ' use this one for 8 mhz and
' also declare the osc as 4mhz
@ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H ; use this one for 32 mhz
@ __CONFIG _CONFIG2L, _BOR_OFF_2L & _BORV_20_2L & _PWRT_ON_2L
@ __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
@ __CONFIG _CONFIG3H, _CCP2MX_OFF_3H
@ __CONFIG _CONFIG4L, _STVR_OFF_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
@ __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
@ __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
@ __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
@ __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
@ __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
@ __CONFIG _CONFIG7H, _EBTRB_OFF_7H
DEFINE OSC 32 ' using HSPLL X 4 gives us OSC 32
@ errorlevel -306 ; turn off the Crossing page boundary warnings
ADCON1 = 7 ' Set to Digital
INTCON2.7 = 0 ' enable pull-up resistor
INTCON2.2 = 1 ' TMR0 Overflow Interrupt Priority bit = 1 = High priority
'--- configuration du timer 0 via T0CON ---
'bit 7 TMR0ON: Timer0 On/Off Control bit
' 1 = Enables Timer0
' 0 = Stops Timer0
'bit 6 T08BIT: Timer0 8-bit/16-bit Control bit
' 1 = Timer0 is configured as an 8-bit timer/counter
' 0 = Timer0 is configured as a 16-bit timer/counter
'bit 5 T0CS: Timer0 Clock Source Select bit
' 1 = Transition on T0CKI pin
' 0 = Internal instruction cycle clock (CLKO)
'bit 4 T0SE: Timer0 Source Edge Select bit
' 1 = Increment on high-to-low transition on T0CKI pin
' 0 = Increment on low-to-high transition on T0CKI pin
'bit 3 PSA: Timer0 Prescaler Assignment bit
' 1 = TImer0 prescaler is NOT assigned. Timer0 clock input bypasses prescaler.
' 0 = Timer0 prescaler is assigned. Timer0 clock input comes from prescaler output.
'bit 2-0 T0PS2:T0PS0: Timer0 Prescaler Select bits
' 111 = 1:256 prescale value
' 110 = 1:128 prescale value
' 101 = 1:64 prescale value
' 100 = 1:32 prescale value
' 011 = 1:16 prescale value
' 010 = 1:8 prescale value
' 001 = 1:4 prescale value
' 000 = 1:2 prescale value
T0CON = %00000010
'--- Déclaration des E/S ---
IN_TLC1966 var porta.0
BP_TEST var portb.7
BP_STOP var portb.6
BP_3MN var portb.5
LED3MN var portb.4
BP_5MN var portb.3
LED5MN var portb.2
BP_10MN var portb.1
LED10MN var portb.0
LED_LOW var portd
LED_HIGH var portc
SORTIE1 var porte.0
SORTIE2 var porte.1
'--- Déclaration des Variables ---
TEMPO var word
X var byte
AFFICHE_TEMPO var byte
START_TEMPO var bit
TMR0RunOn var word
' quartz => 8MHz + HSPLL ==> 32MHz
' Fosc/4 = 8MHz
' sortie1 = not sortie2 = 16HZ => t= 1/16 = 62.5ms => t/2 = 31250µs
' prescaler = 8 ==> TMR0 accuracy = 1µs
' preset TMR0(16bits) = $FFFF - (31250µs) = $FFFF - $7A12 = $85ED
TMR0Preset var word
tmr0preset = $85ED
'--- Valeurs par défaut ---
led_low = 255 ' LED0 to LED7 off
led_high = 255 ' LED8 to LED15 off
led3mn = 1 ' LED3MN off
led5mn = 1 ' LED5MN off
led10mn = 1 ' LED10MN off
'pour test
sortie1 = 0
sortie2 = 1
' sortie1 = 0
' sortie2 = 0
start_tempo = 0
'--- Test à la mise sous tension ---
if bp_stop = 0 and bp_test = 0 then
led_low = 254
pause 200
for x = 1 to 8
led_low = led_low << 1
pause 200
next x
led_low = 255
led_high = 254
pause 200
for x = 1 to 8
led_high = led_high << 1
pause 200
next x
led_high = 255
low led3mn
pause 200
high led3mn
low led5mn
pause 200
high led5mn
low led10mn
pause 200
high led10mn
'--- Début du programme ---
' Initialise TMR0 Interrupts
gosub tictac 'for test
Gosub Set_Timer ' Set the Timer for next 31.25mS Interrupt
On Interrupt goto Tick_Count
INTCON.5=1 ' Enable TMR0 Interrupts
INTCON.6=1 ' Enable all unmasked Interrupts
INTCON.7=1 ' Enable Global Interrupts
DEBUT:
if bp_3mn = 0 then
tempo = 180
low led3mn
high led5mn
high led10mn
goto affichage_tempo
if bp_5mn = 0 then
tempo = 300
high led3mn
low led5mn
high led10mn
if bp_10mn = 0 then
tempo = 600
high led3mn
high led5mn
low led10mn
if bp_test = 1 then goto debut
LECTURE_LTC1966:
' lire entrée analogique
' afficher valeur LTC1966
' if bp_stop = 1 then goto lecture_ltc1966
goto debut
AFFICHAGE_TEMPO:
affiche_tempo = tempo / 16
start_tempo = 1
goto debut
TICTAC:
led_high = 0
pause 200
led_high = 255
pause 200
'--- Gestion des interruptions ---
' Subroutine Loads TMR0 values (based on Melanie's olympic timer)
SET_TIMER:
T0CON.7=0 ' Stop the Clock
tmr0runon.Highbyte=TMR0H ' Load the Run-On (Over-Run) value (if any)
tmr0runon.Lowbyte=TMR0L
tmr0runon=tmr0preset+tmr0runon ' Calculate the New (adjusted) value for TMR0
TMR0H=tmr0runon.Highbyte ' Save new values to TMR0
TMR0H=tmr0runon.Lowbyte
T0CON.7=1 ' Restart the Clock
INTCON.2 = 0 'Reset TMR0's Interupt Flag
' Timer Interrupt Handler
TICK_COUNT:
toggle sortie1
toggle sortie2
Resume
note: TICTAC is only a test witch work only when i delete the line ON INTERRUPT.
i think i mist something on TMR0 configuration but i did not find it.
can someone help me?
MERCI
Bisous de France
sorry for my english !!!!!!!!!!!!!!!!
A quick look and I see a couple thing missing.
DISABLE
TICK_COUNT:
toggle sortie1
toggle sortie2
Resume
ENABLE
SET_TIMER needs work too. With the timer set to 16-bit read/write operation you need to write to TMR0H first, then TMR0L. Reading is just to opposite. Read TMR0L, then read TMR0H.
And, do you really want TMR0H to be loaded with the low & then high bytes of tmr0runon?
This wouldn't work anyhow, since you never write to TMR0L, which loads TMR0H..;o)
HI all,
1- Mackrackit
it's not working where you place them but it's working when i do :
DEBUT:
ENABLE
DISABLE
goto DEBUT
2- Bruce
indeed it was a 'typo' mistake i will write : TMR0L=tmr0runon.Lowbyte
well, for now all is ok so i can go on
thanks for helping
