Uqfn / qfn 16f1827
I need a sanity check... I can program my DIP package for 16F1827 via ICSP. When I try to program
the UQFN exactly the same way it says "target device does not match selected device". I have the
data and clk wires going to the proper ports. I have no caps or resistors in the MCLR where VPP
is connected.
Does the UQFN program differently? I am using the U2 programmer (yes it's firmware has been
updated).
Nick
They should program the same. Just a different package.
Double check your connections, sound like something is wrong there...
I found the problem. The tech ordered the wrong part. He ordered 16LF1827, I was trying to
program it like the regular voltage part. I need to use it with a 3.7v LiPo, so it will not work for me. I ordered the regular voltage rated part, should be here by Thursday.
Nick
Yeap confirmed, the "LF" part didn't program with the USB-U2 programmer. The "F" version programmed nicely without issue using the UQFN package.
Nick
