Some of the newer PIC18s (e.g. 2480, 2580, 4550 etc) support the 'Extended Instruction Set', which enables them to do the offset indexed addressing. However, that's not how mikroC (or any of the MikroE's compilers) has been designed to do. The explanation from Microchip's datasheets for relevant PICs says: When the extended set is disabled, addresses embedded in opcodes are treated as literal memory locations: either as a location in the Access Bank (a = 0), or in a GPR bank designated by the BSR (a = 1). When the extended instruction set is enabled and a = 0, however, a file register argument of 5Fh or less is interpreted as an offset from the pointer value in FSR2 and not as a literal address. For practical purposes, this means that all instructions that use the Access RAM bit as an argument – that is, all byte-oriented and bit-oriented instructions, or almost half of the core PIC18 instructions – may behave differently when the extended instruction set is enabled.
This 'problem' can be solved in two ways:
1. Disable the extended instruction set (e.g. for PIC18F2480, it's in the 4th config word - _CONFIG_4L: _XINST_OFF_4L); it can be done either from the compiler itself (<Project>-><Edit Project>), or in the PICFLASH tool.
2. Leave the extended set enabled, but set the FSR2L and FSR2H to 0's at the beginning of your code; this will make the offset from the location 0x000000, which is the actual address stated. In this case you lose the FSR2 register pair.
I've also seen that config registers can be changed as you said, and thought about disabling extended instructions before running PBP code. It's just a matter of knowing if that can be done within a running program, without messing it up.
