init PORTD FOR 16F877A
		Hello everyone,
Before posting this, I've documented myself, but still I have the same annoying problem for one week now.
I have designed a circuit, using a 16F877A, that is intended to display different
messages on an HD44780 based LCD, when different keys are pressed, along with switching on a LED, corresponding to the key.
For my purpose I use PORT B, as 4bit and control lines for the LCD, and PORT D
as keys interface and LED driver.
The LCD works fine, but my problem is with PORT D. Even if it is switched to general purpose I/O port (bcf TRISE,PSPMODE), and configured accordingly to my needs (movlw   b'00011111'; movwf   TRISD), it acts chaotically, especially on RD 0 to 3, by interpreting the inputs as being key-pressed(0 V), and this combined with the fact that the corresponding LED is not lighting.
Did anyone had this problem also and has a solution to this?
Thank you in advance,
PS: Downwards is a chunk of my code, the init part and how I verify my PORTD imputs and command the LEDs.
list		p=16f877A	; list directive to define processor
	#include	<p16f877A.inc>	; processor specific variable definitions
	__CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _HS_OSC & _WRT_OFF & _LVP_OFF & _CPD_OFF
	ERRORLEVEL	0,	-302
;;;;;;;;;;;;;;; pini necesari LCD;;;;;;;;
#define	D7	PORTB,1
#define	D6	PORTB,2
#define	D5	PORTB,3
#define	D4	PORTB,4
#define	E	PORTB,5
#define	RS	PORTB,7
lcd_port	equ	PORTB
;;;;;;;;;;;;;;;;;;;;;;;;;;;;; LCD
;;;;;;;;;;;;;;;;;;;;;;;BUTOANE
btn_port	equ	PORTD
btn1	equ	0
btn2	equ	1
btn3	equ	2
btn4	equ	3
btn5	equ	4
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; iesiri
#define	out5	PORTB,0
#define	out4	PORTB,6
#define	out3	PORTD,7
#define	out2	PORTD,6
#define	out1	PORTD,5
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; sfarsit definire iesiri
cblock	0x20
	d1,d2,d3,var,var_dly,count
	endc
;;;;;;;;;;;;;;;;;;;;;;;;;   sfarsit declaratii etc
;;;;;;;;;;;;;;;;;;;;;;;;; progr principal
init_porturi:
 ; ports init
	clrf	STATUS
	clrf	PORTB
	clrf	PORTD
	banksel TRISB
	;bsf	OPTION_REG,7
	;bcf	INTCON,4
	clrf	TRISB
; my LCD uses only 6 lines, and 2 pins are used for light switch on, and one for powering up the LCD for proper INITIALIZATION when a
PIC hardware RESET
	bcf	TRISE,PSPMODE
	movlw	0x1f
	movwf	TRISD
	banksel	PORTB
	clrf	PORTB
	clrf	PORTD
	clrf	STATUS
	call	LCD_Init
; ;;;;;;;;;;;;;;;;;end of init side
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; main loop
pre_main:
call	stare_de_veghe
 ; this is something for LCD
;btfss	btn_port,btn1
;call	cmd_1
btfss	btn_port,btn2
call	cmd_2
btfss	btn_port,btn3
call	cmd_3
btfss	btn_port,btn4
call	cmd_4
btfss	btn_port,btn5
call	cmd_5
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;fina  l main loop
cmd_1 ;; the same for rest of cmd mnemonics
; bla bla bla
bsf     out1; set the LED for out1
call delay ; generic 1s delay
bcf    out1; clear LED
;bla bla bla
		Hi, Coss_cat
@ first, i must tell you here is a PicBASIC Pro Forum ... so it is not the best place to ask for Assembler relative questions ... :o
NOW, I see two possibilities ...
1) PortD is controlled by the TrisE register ... so check that.
2) may be a simple debounce problem ... :rolleyes:
		Thank you Acetronics. I am new to the forum, just registered yesterday. I thought it is not such a stupid question to ask for PORTD init, considering the fact that I already did the TRISE thing.
Also it is good to know rules arround, and so please tell me where exactly this thread should be posted. I will try to repair my mistake.
		The best place to ask questions on PIC asembly language would be on the Microchip web forum at http://www.microchip.com/forums/Default.aspx?
This forum is for the MicroengineeringLabs PicBasic Pro & Picbasic compilers.
The primary focus here is helping folks having problems with BASIC, but we do on occasion offer help with assembler.
You should have external pull-up resistors holding your portd inputs high, with each button press grounding an input pin. If you don't have the external pull-ups that would explain erratic behaviour.
Also - be sure on return from any called routine that you're in the proper bank to test portd pins.
I would post all of your code on the Microchip forum for quicker help. It's hard for people to help if they can't see all of your code since the parts you don't show could be where the problem is.
