I have a code that works great with the DS1820, however when i change to a DS18S20, the only thing that i get is 127.68ºC.
I allready made a search on the forum, however all the resaults are exactly the same as my code.
I have 2 DS18S20, and the show exactly the same value.
Can somebody help me;
Here is my code.
count_remain Var Byte ' Count remaining
count_per_c Var Byte ' Count per degree C
temperature Var Word
' REGISTOS PINOUT 1 = IN; 0 = OUT
'76543210
TRISA = %11111111
TRISB = %00001111
TRISC = %00100000
TRISD = %00000000
TRISE = %00000000
ADCON1 = %00001110
ADCON0 = %00000000
' NOMES PINOUT
LED VAR PORTC.3
DQ VAR PORTD.0
' DEFENIÇÕES
DEFINE LCD_DREG PORTB ' LCD Data bits on PORTB
DEFINE LCD_DBIT 4 ' PORTB starting address
DEFINE LCD_RSREG PORTB ' LCD RS bit on PORTB
DEFINE LCD_RSBIT 3 ' LCD RS bit address
DEFINE LCD_EREG PORTB ' LCD E bit on PORTB
DEFINE LCD_EBIT 2 ' LCD E bit address
DEFINE LCD_BITS 4 ' LCD in 4-bit mode
DEFINE LCD_LINES 2 ' LCD has 2 rows
DEFINE LCD_COMMANDUS 2000 ' Set command delay time in us
DEFINE LCD_DATAUS 50 ' Set data delay time in us
' INICIO PROGRAMA
gosub Read_Sensor_Amp
goto Main
' LEITURA SENSOR AMPLIFICADOR
Read_Sensor_Amp:
OWOut DQ,1,[$CC,$44]
Waitloop: OWIn DQ,4,[count_remain]
If count_remain = 0 Then Waitloop
OWOut DQ,1,[$CC,$BE]
OWIn DQ,0,[temperature.LOWBYTE,temperature.HIGHBYTE,Skip 4,count_remain,count_per_c]
temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100)/count_per_c)
Lcdout $fe, 1, " Temp. Amplificador "
Lcdout $fe, $C0," ",DEC (temperature/100),".",DEC2 temperature," C"
