Hello
I want a sample program in pbp, I want to send
15 bytes by the bias of an RF module 433 MHz and receive
On another module.
thank you
Hello
On another module.
thank you
Have you searched the forum for examples? There a plenty out there.
Can you send and receive the data with wires?
Hello
I will test this way?
touche VAR BYTE
name0 var byte
name1 var byte
name2 var byte
name3 var byte
i var byte
ID Var Byte
envoi:
SEROUT2 PORTA.3,T9600,["SYN",ID,name0,name1,name2,name3]
GOTO debut
reception:
Serin2 PORTA.3,T9600,[wait("#SYN"),ID,name0,name1,name2,name3]
GOTO debut
Maybe without the "#" symbol on he SERIN command.
Hello
Thank you for your help, do you have a sample program.
I want to transmit and receive 24 bytes.
thank you
If your data are always 24, then use an array, load the date at the array elements and then send the array.
I 'd use Hserout if my controller has hardware USART.
Hserout [STR array\24]
or
SerOut2 port,mode,[STR array\24]
Hello
Thank you for your help, what do you think of this program?
Compteur Var Byte '
TX_Donnee Var Byte[24] ' Donnee emission
RC_ID Var Byte ' emission IDentificateur
RX_Donnee Var Byte[24] ' Donnee reception
Loop: ' emission
For Compteur = 0 to 23 ' donnee
TX_Donnee = Compteur ' Transfert de Compteur vers TX_Donnee
Serout2 PortA.0,B2400,["#OK",RC_ID,TX_Donnee] ' envoie l'ID suivie des donnnees
Pause 100 '
Next
Goto Loop
Loop1: ' reception
Serin2 PortA.1,B4800,[wait ("#OK"),RC_ID,RX_Donnee] ' attend reception l'ID
if ID=32 THEN
Goto Loop1 ' boucle
Sorry but no!
You lack basic knowledge of the lanquage syntax.
I am sorry to say that, but you must read the PBP manual and test the commands before doing this.
Just to help you going, arrays are accessed by their element position, e.g. TX_Donnee = Compteur is wrong and should be TX_Donnee[Compteur] = Compteur.
You might want to verify your send/receive data rates as well.
Hello
Thank you for your help, I'll try this way?
j var byte
datac Var Byte '
Loop: ' emission
ID=32 ' l'ID
For J = 0 to 23 '
TX_Donnee[J] = datac ' Transfert de datac vers TX_Donnee
Serout2 PortA.0,B2400,["#OK",ID,TX_Donnee] ' envoie l'ID suivie des donnees
Pause 100 '
Next J
Goto Loop
Loop1: ' reception
Serin2 PortA.1,B4800,[wait ("#OK"),ID,RX_Donnee] ' attend reception l'ID suivie des donnees
if ID=32 THEN
For j = 0 to 23 '
datac[J] = RX_Donnee ' Transfert de datac vers TX_Donnee
next j
Goto Loop1 ' boucle
No, you receive loop is wrong in the logic.
Try this for the receive part:
Code:j=0
While j<24' reception
if ID=32 THEN
j=j+1
Wend ' boucle
hello
thank you for your help
