ERROR: Unable to execute mpasmwin.Error[116] C:\PROD\X-10 G4 SPEL\INT GEN 4 VAST.ASM 940 : Address label duplicated or different in second pass (Z00031)
Error[116] C:\PROD\X-10 G4 SPEL\INT GEN 4 VAST.ASM 1003 : Address label duplicated or different in second pass (Z00032)
Error[116] C:\PROD\X-10 G4 SPEL\INT GEN 4 VAST.ASM 1056 : Address label duplicated or different in second pass (Z00033)
Error[116] C:\PROD\X-10 G4 SPEL\INT GEN 4 VAST.ASM 1087 : Address label duplicated or different in second pass (Z00034)
Halting build on first failure as requested.
BUILD FAILED: Mon May 10 10:39:18 2010
If I look in the ASM file for Z00031 I find this:
; C:\PBP\DT_INTS-18.BAS 00313 Z00031 asm
Z00031
ASM?
; -- Added for ver. 3.2 --
ifdef SPPIF ;----{ Streaming Parallel Port Read/Write }--[PIR1, SPPIF]---
INT_Source PIR1,SPPIF, PIE1,SPPIE, IPR1,SPPIP
ifdef BCL1IF ;----{ Bus 1 Collision }--------------------[PIR2, BCL1IF]---
I bet someone have seen this before or at least can give me a clue where to go hunting or do I need Mr DT to go hunting in the 3.2 version upgrade?
