Please help me understand this code
From the code bellow, I am expecting to have the DEBUG line running only when the variable "ReadFlag" is set and it does, so far so good.
But once it ran, I clear ReadFlag and it should become set again ONLY if I=10 and this should happen only after the Interrupt has ran 10 times right? Well it is not happening.
In my DEBUG line "I" shows up as 0,2,4,5 randomly
I am not using variable "I" anywhere else other than: at the top of my program.
Can someone help me understand this?
Goto main
DO while readflag = 1
debug dec Fvalue," i=",dec i," R=",dec readflag,10,13 ; Display on terminal if ReadFlag = 1
readflag = 0 ; do not update until the next 10 readings
Fvalue = 0
LOOP
'---[INT - interrupt handler]------Signal found at RB0, take a reading
SignalFound:
T1CON.0 = 0 ; Stop timer1
i = i + 1
FValue = TMR1H * 256 + TMR1L + fvalue ; Add 10 readings to FValue
if i = 10 then
fvalue = fvalue / 10 ; get the average of one reading
i = 0 ; Reset counter
ReadFlag = 1 ; FValue is ready to read
TMR1H = 21 ; reset timer1 to 60mS
TMR1L = 167
T1CON.0 = 1 ; Start timer1
@ INT_RETURN
Mike
