		PWM=on...DEBUG=off
		Hi guys,
 i'm building a project to test piezos and check what is the best working frequency.
 I'm using a 12F615 and the code is very simple:
 send frequency out using HPWM and when the sound from the piezo sounds about right and pressing a switch the frequency value will output via RS232.
 The problem i'm having is that when activating HPWM the debug function does not work.
 If i remove the bold definitions ( see below ) the debug works.
 [code]
 DEFINE OSC 8
 OSCTUNE=%0000000
 @ DEVICE PIC12F615, INTRC_OSC_NOCLKOUT
 @ DEVICE PIC12F615, WDT_OFF
 @ DEVICE PIC12F615, PWRT_OFF
 @ DEVICE PIC12F615, MCLR_OFF
 @ DEVICE PIC12F615, BOD_OFF
 @ DEVICE PIC12F615, PROTECT_ON
 @ DEVICE PIC12F615, IOSCFS_8MHZ
 '*************************************************  *****************ADCON0=0
 ANSEL=0
 WPU=0                         ' Disable pull-ups
 CMCON0.7=0                ' Turn off comparator
 INTCON=0                     ' Interrupt control register
 OPTION_REG.7=1         ' Disable Pull-Ups
 OPTION_REG.3=1         ' Disable Pull-Ups
 CCP1CON=%10001100  ' PWM mode; P1A active-high; P1B active-high
 PWM1CON=%10000001  ' min dead-band time
 T2CON.2=0
 T1CON.3=0
 VRCON=0                    ' Internal Vref disabled
 TRISIO=%011001
 GPIO=0
 'PINS
 sw1          var GPIO.0  'stop switch
 out           var GPIO.1  'OUT PIN for debug
 piezo       var GPIO.2  'output pwm
 in          var GPIO.3  'Input
 sw2          var GPIO.4  'spare switch
 Led         var GPIO.5  'Led
 PI1         var word
 na          var word
 duty        VAR WORD
 freq        var word
 Include "modedefs.bas" ' Include serial modes
 DEFINE DEBUG_REG GPIO
 DEFINE DEBUG_BIT 1
 DEFINE DEBUG_BAUD 9600
 DEFINE DEBUG_MODE 1
 'PWM
 DEFINE CCP1_REG GPIO 'Hpwm 1 pin port
 DEFINE CCP1_BIT 2    'Hpwm 1 pin bit
 INIT:
 high out
 debug $0D, $0A
 PAUSE 50
 debug "Starting...",13,10
 debug 13,10
 low led
 Duty = 127  '50% duty
 debug "started frequency loop",13,10
 start:
 debug 13,10
 debug 13,10
 low led
 for freq=2000 to 4000 step 10
 HPWM 1,duty,freq
 debug dec freq,13,10
 debug 13,10
 pause 50
 if sw1=1 then
 while sw1=1
 wend
 goto play
 next
 high led
 pause 300
 goto start
 play:
 debug "freq=",dec freq,13,10
 [code\]
 Any help would be appreciated
		Hi there,
 anyone has any idea that can help me ?
		Just a suggestion.  Can you not send the frequency after SW1 is hit?  Or does that not work as well?
		Greetings Jerson,
 thank you for your reply
 One question:
 When needed to stop the HPWM we just place a zero duty value but internally the module is still active and on standby.
 Is it possible to really shutdown the HPWM module, like for example placing the "CCP1CON=0" in the code's last loop ?
		Greetings ruijc
 Setting HPWM value to 0 should be sufficient to keep the output off, but, it should be ok to put it off as you suggested.
